iProps in Inventor 2018 have trailing zeros even when rounded to 0 D.P.
Message 1 of 10
I have several iLogic driven templates set up for products, and have noticed since getting Inventor 2018 that rounding a custom iProperty to 0 decimal places, still displays it with .0 , even though Inventor does not recognise the .0.
For example, we have a custom iProperty for Mass in Air, when we run the 'Update Weights' rule, an input box asks for the number of decimal places required. When selecting '0' the resulting iProperty would read as 111.0 for example. Inventor 2017 did not have the .0 displayed.
If I try and remove the .0 zero by asking to go right 2 places, the iProperty would then give me '11'  which makes me think Inventor is not seeing the .0 even though it is displayed.
The attached screenshots show the actual mass, the 'WIA' iProperty with 2 decimal places, and with 0 decimal places.
The 0 decimal places displays '2.0' even though it should read '2'
Anyone else come across this or have a fix for it?
Chris Jones
Replies (9)
Message 2 of 10
bradeneuropeArthur
This has all to do with the documentsettings.
change these and it will be correct.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 10
It doesn't work, already tried that. The custom iProperty still has the .0 on the end.
Inventor 2017 didn't have this issue even with having the precision at 3 DP in document settings.
Message 4 of 10
bradeneuropeArthur
can you upload the rule for the weight please.
The failure will be found there, since the WIA is no expression.
Because it is no expression the failure is in the rule.
Why are you not using:
WIA =<Mass>
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 10
This is what we use (it's a global rule).
We don't use the Mass property as in drawings if it is out of date, it displays 'N/A' so we created a mapped property so a value is always displayed.
The rule has always worked fine until we got 2018, and now we have this issue with the extra 0. Weights are important on our drawings as it is the offshore business.
Thanks for looking at this.
Message 6 of 10
bradeneuropeArthur
Think inventor changed a little:
this is working:
Dim Rounding As Integer
Rounding = InputBox("dd", "dddd", "0")
Dim m As Decimal= iProperties.Mass
MsgBox(Round(m,Rounding))
iProperties.Value("custom","WIA") = Round(m,Rounding).tostring
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 10
Great!
Thanks for that. Will give that a try and let you know how it goes.
Message 8 of 10
rhasell
This one caught my attention, because I run the same code.
I made some small changes to mine, and am unable to duplicate your error.
Is your Inventor patched etc?
Here is a copy of testing your code, combined with mine, it all works as expected.
(Its not the cleanest, just testing.)
iProperties.Value("Custom", "Totalmass") = Round(iProperties.Mass, Rounding) & " kg"
MessageBox.Show(iProperties.Value("Custom", "Totalmass"), "Title")
Reg
2026.1
Message 9 of 10
HI,
Yeah, Inventor is up to date with the latest patch.
I wonder if your code works better as your adding the "kg" on to the end of it where mine was just a number?
I'll try my code that way to see If that also fixes the error.
Message 10 of 10
bradeneuropeArthur
@Anonymous
Please try the earlier posted code with the correct declarations, as m as  decimal.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
