iProperties Add Property to Project tab - API VB.NET
florian_wenzel
florian_wenzel
Inventor 2022
API VB.NET Visual Studio
i try to add a Property to iProperties exyctly to Project Tab ("Design Tracking Properties").
But without success.
Is this possible, add to Project ?
The Goal is to get something like this.
This is my Code:
Imports System.Runtime.InteropServices
Imports Inventor
Imports Microsoft.Win32
Imports System.Collections.Generic
Imports System.Linq
Imports System.IO
Module CommandFunctionButton_12
    Public Sub CommandFunctionfweButton_12()
        Dim oPartDoc As PartDocument = g_inventorApplication.ActiveDocument
        Dim oCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
        Dim oTO As TransientObjects = g_inventorApplication.TransientObjects
        Dim oTG As TransientGeometry = g_inventorApplication.TransientGeometry
        Dim oProperty As Inventor.Property
        Dim oPropertySet As Inventor.PropertySet
        oPropertySet = oPartDoc.PropertySets.Item("Design Tracking Properties")
        'oPropertySet = oPartDoc.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}")
        oProperty = oPropertySet.Add("204", "MaterialCode")
    End Sub
End Module
Error:
Unknow Error
Thanks for any Sugestion.
bradeneuropeArthur
With this you add a propertyset no property.
You need to do
Propertyset.item(***).add(###)
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Curtis_Waguespack
Hi @florian_wenzel
We do not have access to create iProperties on the standard tabs.
You will need to add your new property to the Custom tab.
oPropertySet = oPartDoc.PropertySets.Item("Inventor User Defined Properties")
I hope this helps.
Curtis
florian_wenzel
Hi Curtis_Waguespack
Thanks for Answer,
Good to Know, that we are not able to do this.
Because i need this in Bill of Materials, and when i will be able to add a Property to Project tab, then it will be a easy step to add this to Bill of Materials.
And are we able to Change the Name of the Property in Project tab?
what do displayName?
Ok i got it.
Add Custom iProperty Columns   - in Bill of Materials
