variables to parameters of an assembly
18297BQ37M
18297BQ37M
Hello, I am new to inventor and I would like to pass my text type variables to parameters of an assembly, but when I execute it, it does not pass the variables to the inventor.
If someone could help me or pass a tutorial to give me a reference, it would be very helpful.
I attach my code and my form next to where I want it to be displayed in inventor.
Imports System
Imports System.Type
Imports System.Activator
Imports System.Runtime.InteropServices
Imports Inventor
Public Class Form1
Dim _invApp As Inventor.Application 'Variable que hace referencia a inventor la cual se utilizará para proporcionar un acceso rápido al objeto de aplicación de Inventor
Dim _started As Boolean = False
Dim Panel_PanelRef As String
Dim Panel_PanelWidth As String
Dim Panel_PanelHeight As String
Dim Panel_PanelThickness As String
Dim oPartDoc As PartDocument
Public Sub New()
' Esta llamada es requerida por el diseñador.
InitializeComponent()
'Añadir cualquier inicialización después de la llamada InitializeComponent()
Try
_invApp = Marshal.GetActiveObject("Inventor.Application") 'Esta variable contiene un objeto de tipo inventor
Catch ex As Exception
Try
Dim invAppType As Type =
GetTypeFromProgID("Inventor.Application")
_invApp = CreateInstance(invAppType)
_invApp.Visible = True
_started = True
Catch ex2 As Exception
MsgBox(ex2.ToString())
MsgBox("Unable to get or start Inventor")
End Try
End Try
End Sub
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
Panel_PanelRef = TextBox1.Text
Panel_PanelWidth = TextBox2.Text
APanel_PanelHeight = TextBox3.Text
Panel_PanelThickness = TextBox4.Text
Try
MessageBox.Show("Cannot connect to Inventor")
End Try
oPartDoc = _invApp.ActiveDocument
oPartDoc.ComponentDefinition.Parameters.Item("API_Panel_PanelRef").Expression = Panel_PanelRef
oPartDoc.ComponentDefinition.Parameters.Item("API_Panel_PanelWidth").Expression = Panel_PanelWidth
oPartDoc.ComponentDefinition.Parameters.Item("API_APanel_PanelHeight").Expression = APanel_PanelHeight
oPartDoc.ComponentDefinition.Parameters.Item("API_Panel_PanelThickness").Expression = Panel_PanelThickness
oPartDoc.Update()
End Sub
Private Sub Form1_FormClosed(sender As Object, e As FormClosedEventArgs) Handles Me.FormClosed
' Esto cerrará la sesión de Inventor iniciada cuando se inició el formulario
If _started Then
_invApp.Quit()
_invApp = Nothing
'Aquí se sale de la sesión de Inventor si _started está establecido en True (es decir, fue el código el que inició la sesión, ya que uno aún no se estaba ejecutando).
End Sub
End Class
A.Acheson
Is it possible to edit your original post and place the code into the code editor and select vb code. When pasted directly in the post the formatting is all messed up and difficult to read. The button for code editor looks like </>.
Do you know  what errors your code has? Is there errors in the debug section of visual studio? Are you getting string values from the form to a message box? Is inventor opened allready to a document? If not there is no might not be an active document. You could use Documents.Open to open a specific document. If that works your problem is further down.
_invApp.Documents.Open("C\User\TempPart.ipt,True)
Regards
Alan
A.Acheson
A few observations.
  1. There is a call to sub routine. Make sure there is a sub routine otherwise remove.
      2. Declaration of String is this "Panel_PanelHeight
Written later incorrectly as
Dim APanel_PanelHeight As String
Regards
Alan
18297BQ37M
tells me that the parameter is incorrect
Imports System
Imports System.Type
Imports Inventor
Public Class Form1
    Dim assemblies As AssemblyDocument
    Public Sub New()
        Try
            Try
                _started = True
            End Try
        End Try
    End Sub
        Try
        End Try
        assemblies = _invApp.ActiveDocument
        'oPartDoc = _invApp.ActiveDocument
        assemblies.ComponentDefinition.Parameters.Item("API_Panel_PanelRef").Expression = Panel_PanelRef
        assemblies.ComponentDefinition.Parameters.Item("API_Panel_PanelWidth").Expression = Panel_PanelWidth
        assemblies.ComponentDefinition.Parameters.Item("API_APanel_PanelHeight").Expression = Panel_PanelHeight
        assemblies.ComponentDefinition.Parameters.Item("API_Panel_PanelThickness").Expression = Panel_PanelThickness
        assemblies.Update()
    End Sub
        If _started Then
            _invApp.Quit()
        _invApp = Nothing
    End Sub
    Private Sub Button2_Click(sender As Object, e As EventArgs) Handles Button2.Click
        _invApp.Documents.Open("C:\Users\Practicante1\Downloads\DoorAndFrame-20220908-1155\DoorAndFrame\DoorAndFrameAssemblyMaster.iam", True)
    End Sub
End Class
A.Acheson
I think the issue here is "Parameter.Expression" is used for changing the expression of a formula and is failing for a text parameter.
Use "Parameter.Value" Instead for modifying values not requiring an expression.
'Option 1
' Declare as Inventor parameter. Generic and can be any parameter
Dim TempParameter As Inventor.Parameter = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("Temp")
TempParameter.Value = "Hello"
'Option 2
' Declare as specifically as Inventor parameter.
Dim TempUserParameter As Inventor.UserParameter = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Userparameters.Item("Temp")
TempUserParameter.Value = "Hello"
Regards
Alan
