Creating DWFs of Pressed Parts
donaldleigh
donaldleigh
Evening all
I have a rule "Create DXF of Pressing" that when run with a sheet metal part open will create a DWF of the part.
I also have another rule "Bend Existing in Sheet Metal" that when run from an assembly will find all parts that are sheet metal with bends.
In the "Bend Existing in Sheet Metal" If a sheet metal part with a bend is found it should run the "Create DXF of Pressing" rule. Currently what is happing is its creating a DWF of the assembly the rule "Bend Existing in Sheet Metal" is run in. But is naming the DWF as per a iproperty of the sheet metal part.
Any help would be great.
Donald
2022
What I would like to do is combine them together, Either as 2 separate rules or 1.
A.Acheson
Here is an attempt. Room for improvement on formatting and duplications. Note the document reference on ilogic iproperty snippet. You could also replace this with propertyset reference.
Sub Main
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
For Each docFile In oDoc.AllReferencedDocuments
	If docFile.IsModifiable = True Then 'Modifiable Part
		If docFile.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then 'Sheet Metal part
			Dim sm As SheetMetalComponentDefinition
			sm = docFile.ComponentDefinition
			If sm.Bends.Count > 0 Then 'Bend Exist
				Dim docName As String
				docName = System.IO.Path.GetFileNameWithoutExtension(docFile.FullFileName)
FileName = System.IO.Path.GetFileName(docFile.FullFileName)
				oFolder = ThisDoc.WorkspacePath() & "\_Pressing DWFs"
				FolderAndFileName = oFolder & iProperties.Value(FileName,"Custom", "DXF Number") & ".dwf"
				docFile.Document.SaveAs(FolderAndFileName, True)
				'MessageBox.Show("Find Pressing" & docName, "Title")
 CreateDxf(docFile.Document,FileName)
			Else If sm.Bends.Count = 0 Then	'No Bend Exist
Next
MessageBox.Show("DWF Of Pressing Created", "Title")
End Sub
Sub CreateDxf(oDocument,FileName)
Dim ThisApp = ThisApplication'.ActiveDocument
Dim TransObj As TransientObjects = ThisApp.TransientObjects
DWFAddIn = ThisApp.ApplicationAddIns.ItemById("{0AC6FD95-2F4D-42CE-8BE0-8AEA580399E4}")
oContext = TransObj.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = TransObj.CreateNameValueMap
oDataMedium = TransObj.CreateDataMedium
If DWFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
	oOptions.Value("Launch_Viewer") = launchviewer
	oOptions.Value("Publish_All_Component_Props") = 1
	oOptions.Value("Publish_All_Physical_Props") = 1
	oOptions.Value("Password") = 0
'get DWG target folder path
oFolder = ThisDoc.WorkspacePath() & "\_Pressing DWFs\"
'Check for the _DWG folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
	System.IO.Directory.CreateDirectory(oFolder)
'MessageBox.Show("Create Pressing" & FolderAndFileName, "Title")
oDataMedium.FileName = FolderAndFileName
'Publish document.
Call DWFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Sub
Here is an attempt. Note reference to reference FileName in iproperty.  If iproperty has no additional target object it is the iproperty of the document the rule is running in.  Use Sub routines to easily combine the code sections. There is room for improvement removing duplicate references but maybe you want to keep rule seperate.
Sub Main
Next
End Sub
'Publish document.
End Sub
Regards
Alan
