iPart/ iAssembly Balloon numbering correction
Hi Everyone,
When you have iParts in an iAssembly, and you set the item number of the iPart to a certain number. When you change the iAssembly to a different member and it changes the iPart to a different member also it changes the item number. Is there a way to stop that from happening? If not has someone got a tip on how to go about coding something to keep the item numbers or change the item numbers back after a change to the iassembly member?
Example:
The iAssembly is set to member MyAssy1, and the iPart is set to member MyPart1 also in the MyAssy1 iassembly member. In MyAssy2 the iPart is set to MyPart4. The item number for the occurrence for MyPart will change to a different item number. We need the item numbers to remain constant through all of the versions of MyAssy.
I sure hope that is clear enough. 😎
Meck
Master Drafter/ CAD Programmer
Using Inventor 2018
