Inventor Vault Add In
Message 1 of 13
Hi all,
I have a bunch of parts/assemblies/drawings in which I need to update a user parameter .
Following is my requirement:
1. check-out file
2. update user parameters and save
3. check-in file
I already have a VB application which can open files in Inventor, update user parameters and Save. The part which involves Vault(check-in & check-out) is what I am not sure of.
Is it possible to do the above steps using Vault plug-in API through Inventor? If not, please advise a suitable way.
Thanks in advance!
Replies (12)
Message 2 of 13
JelteDeJong
I know its possible to use the vault API. But it's very difficult. I have a tool that does something similar and use a different approach. You can execute the check-in command from within inventor. That will check-in the file that you have opened at that moment but it will show you the standard check-in dialog. To work around that you can suppress that dialog when you start your program.
To execute the check-in use this code.
ThisApplication.CommandManager.ControlDefinitions["VaultCheckinTop"]
oCtrlDef.Execute2(true)
you can suppress the dialog like this:
Jelte de Jong
Blog: hjalte.nl - github.com
Message 3 of 13
bradeneuropeArthur
You need a vault extension/addin to update that property?
Or do you need an inventor addin that uses the Vault API to update the property?
Both is possible!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 4 of 13
Actually I need to update a user parameter inside the file. And that parameter is not mapped as a property in Vault. So check-out and check-in is definitely required.
And that is why I was thinking of check-out and check-in at the first place. Had it been a mapped property I could have just updated it from Vault.
Either way will work. But I would prefer if it's  " inventor addin that uses the Vault API " because then I will be able to control the check-in, check-out and model parameters from a single application.
Message 5 of 13
Hi, Thanks for the answer.
I tried the following code as suggested:
Dim dInv As Inventor.Application
Dim oCtrlDef As ControlDefinitions
oCtrlDef = dInv.CommandManager.ControlDefinitions["VaultCheckinTop"]
oCtrlDef.Execute2(True)
But I am getting an error. See attached image.
I am using Visual Studio - Windows Form Application (VB).
Kindly let me know what is missing/wrong.
Message 6 of 13
JelteDeJong
I copied that code from a c# app.  This will probably work better:
oCtrlDef = dInv.CommandManager.ControlDefinitions.Item("VaultCheckinTop")
Jelte de Jong
Message 7 of 13
Hi.
What's the difference between ("VaultCheckin") & ("VaultCheckinTop") ?
Message 8 of 13
bradeneuropeArthur
Checkin is for the selection if I am correct!
Checkintop for the top assembly or part in browser, no selection required!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 13
I am still getting an error. But this time error is different.
I think I am missing some reference or library files. Can you help on this?
See attached image for the error message.
Message 10 of 13
bradeneuropeArthur
Do you have a selection active?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 13
I am using the below code.
I am able to open the file successfully and after that the code throws the error. I believe the opened file is the selection that you had asked. Right? If not, then I am not aware what selection are we talking about.
Dim FileName As String
        FileName = "C:\V\HEX\Designs\GPHE Global Product Platform\FRAMES\CAPELLA\C063MA60A\C063MA50A-F-P.ipt" 'ComboBox1.Text
Dim odoc As PartDocument
odoc = dInv.Documents.Open(FileName)
        ' Trying to check-out the file
oCtrlDef = dInv.CommandManager.ControlDefinitions.Item("VaultCheckoutTop")
Message 12 of 13
bradeneuropeArthur
The code in the screenshot is different. Vaultcheckout!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 13
I tried with 'Vaultcheckout' too. Same issue is coming.
