Inventor Template issue
Fairly new to inventor.  I can use it well enough to be dangerous (I'm an electrical guy).  Starting to get more into the Inventor realm out of necessity however.  First order of business (aside from more classes...) is updating our title block/template with companies logo.  I have DONE that.  However, when I go to create a new a drawing, it still gives me the OLD version of 'standard.dwg', without the changes I made.  What is going on, and how can I fix it?  I didn't alter anything else on the base drawing (titleblock wise).  Merely added our company logo and some other generic text
Thoughts?
Doug (no.  The OTHER one.)
MechMachineMan
1) This is a better question for the general forums but
2) Check that the location that the template is stored in matches what you applications options/project setting are pulling from.
3) Hit the new button directly so that the dialog button pops up and then you select your template from there.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
