Inventor | Material | Update Description
How would I update description property from 'Identity' tab of a material from VBA?
I could access couple of other properties, but not description. Can you help?
bradeneuropeArthur
If I am not wrong than this is not supported from the API.
https://forums.autodesk.com/t5/inventor-customization/creating-material-asset-where-is-the-descripti...
@johnsonshiue could you check this for @Anonymous , please?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
