Hey
you might be best adding the buttons independently rather than trying to rely on a function to create them. Here is the code i use-
AddinGlobal Class
Imports System
Imports System.Collections.Generic
Imports System.Runtime.InteropServices
Imports Inventor
Public Class AddinGlobal
Public Shared InventorApp As Inventor.Application
Public Shared RibbonPanelId As String
Public Shared RibbonPanel As RibbonPanel
Public Shared ButtonList As List(Of InventorButton) = New List(Of InventorButton)()
Private Shared mClassId As String
Public Shared Property ClassId As String
Get
If (Not String.IsNullOrEmpty(mClassId)) Then
Return AddinGlobal.mClassId
Else
Throw New System.Exception("The addin server cannot be found!")
End Get
Set
AddinGlobal.mClassId = Value
End Set
End Property
Public Shared Sub GetAddinClassId(ByVal t As Type)
Dim guidAtt As GuidAttribute = GuidAttribute.GetCustomAttribute(t, GetType(GuidAttribute))
mClassId = "{" + guidAtt.Value + "}"
End Sub
End Class
InventorAddinServer Class
populate the private variables at the top (RibbonName, AddTab, MyTabName etc)
add your application GUID. i have added 2 buttons to this class with an icon for each. you will need to edit the button descriptions
Imports System
Imports System.Reflection
Imports System.Windows.Forms
Imports System.Drawing
Imports Inventor
<Guid("add your GUID here")>
Public Class InventorAddinServer
Implements ApplicationAddInServer
Private RibbonName As String = "Part"
Private AddTab As Boolean = False
Private MyTabName As String = "id_TabModel"
Private MyTabID As String = "id_Tabid_" & MyTabName
Private MyPanel As String = "My Panel"
Private Button1Title As String = "My Button 1"
Private Button1Description As String = "My Button 1 Description"
Private Button1ToolTip As String = "My Button 1 Tooltip"
Private Button2Title As Stringg = "My Button 2"
Private Button2Description As String = "My Button 2 Description"
Private Button2ToolTip As String = "My Button 2 Tooltip"
Sub New()
End Sub
''' <summary>
''' Do initializations in it such as caching the application object, registering event handlers, and adding ribbon buttons.
''' </summary>
''' <param name="siteObj">The entry object for the addin.</param>
''' <param name="loaded1stTime">Indicating whether the addin is loaded for the 1st time.</param>
Sub Activate(ByVal siteObj As ApplicationAddInSite, ByVal loaded1stTime As Boolean) Implements ApplicationAddInServer.Activate
AddinGlobal.InventorApp = siteObj.Application
Try
AddinGlobal.GetAddinClassId(Me.GetType())
'create your icons, make sure they are embedded and added to the resources
Dim icon1 As Icon = New Icon(Me.GetType(), "MyIcon1.ico")
Dim icon2 As Icon = New Icon(Me.GetType(), "MyIcon2.ico")
Dim button1 As InventorButton = New InventorButton(Button1Title, "InventorAddinServer.Button_" + Guid.NewGuid().ToString(), Button1Description, Button1Tooltip, icon1, icon1, CommandTypesEnum.kShapeEditCmdType, ButtonDisplayEnum.kDisplayTextInLearningMode)
button1.SetBehavior(True, True, True)
button1.Execute = AddressOf ButtonActions.Button1_Execute
Dim button2 As InventorButton = New InventorButton(Button2Title, "InventorAddinServer.Button_" + Guid.NewGuid().ToString(), Button1Description, Button1Tooltip, icon2, icon2, CommandTypesEnum.kShapeEditCmdType, ButtonDisplayEnum.kDisplayTextInLearningMode)
button2.SetBehavior(True, True, True)
button2.Execute = AddressOf ButtonActions.Button2_Execute
If (loaded1stTime = True) Then
Dim uiMan As UserInterfaceManager = AddinGlobal.InventorApp.UserInterfaceManager
'kClassicInterface support can be added if necessary.
If (uiMan.InterfaceStyle = InterfaceStyleEnum.kRibbonInterface) Then
Dim ribbon As Inventor.Ribbon = uiMan.Ribbons(RibbonName)
Dim tab As RibbonTab = Nothing
Select Case AddTab
Case True
Try
'Change it if necessary.
tab = ribbon.RibbonTabs(MyTabName)
Catch
tab = ribbon.RibbonTabs.Add(MyTabName, MyTabID, Guid.NewGuid().ToString())
End Try
Case False
End Select
AddinGlobal.RibbonPanelId = "{ae9863ba-cf99-4cdd-93ce-6ebfa99ac23b}"
AddinGlobal.RibbonPanel = tab.RibbonPanels.Add(MyPanel, "InventorAddinServer.RibbonPanel_" + Guid.NewGuid().ToString(), AddinGlobal.RibbonPanelId, String.Empty, True)
Dim cmdCtrls As CommandControls = AddinGlobal.RibbonPanel.CommandControls
cmdCtrls.AddButton(button1.ButtonDef, button1.DisplayBigIcon, button1.DisplayText, "", button1.InsertBeforeTarget)
cmdCtrls.AddButton(button2.ButtonDef, button2.DisplayBigIcon, button2.DisplayText, "", button2.InsertBeforeTarget)
Catch e As Exception
MessageBox.Show(e.ToString())
End Try
Try
'Change it if necessary but make sure it's embedded.
End Try
' TODO: Add more initialization code below.
mTransactionEvents1 = New TransactionEvents1(AddinGlobal.InventorApp.TransactionManager.TransactionEvents)
mTransactionEvents1.Register()
End Sub
''' <summary>
''' Do cleanups in it such as forcing GC Collection and closing log files.
''' </summary>
Sub Deactivate() Implements ApplicationAddInServer.Deactivate
mTransactionEvents1.UnRegister()
End Sub
''' <summary>
''' Deprecated. Use the ControlDefinition instead to execute commands.
''' </summary>
''' <param name="commandID"></param>
Sub ExecuteCommand(ByVal commandID As Integer) Implements ApplicationAddInServer.ExecuteCommand
End Sub
''' <summary>
''' Implement it if wanting to expose your own automation interface.
''' </summary>
ReadOnly Property Automation As Object Implements ApplicationAddInServer.Automation
Get
Return Nothing
End Get
End Property
Dim mTransactionEvents1 As TransactionEvents1
End Class
InventorButton Class
Imports System
Imports Inventor
'Namespace ViewLabels
''' <summary>
''' The class wrapps up Inventor Button creation stuffs and is easy to use.
''' No need to derive. Create an instance using either constructor and assign the Action.
''' </summary>
Public Class InventorButton
#Region "Fields And Properties"
Private mButtonDef As ButtonDefinition
Public Property ButtonDef As ButtonDefinition
Get
Return mButtonDef
End Get
Set
mButtonDef = Value
End Set
End Property
#End Region
#Region "Constructors"
''' <summary>
''' The most comprehensive signature.
''' </summary>
Sub New(ByVal displayName As String, ByVal internalName As String, ByVal description As String, ByVal tooltip As String, ByVal standardIcon As Icon, ByVal largeIcon As Icon, ByVal commandType As CommandTypesEnum, ByVal buttonDisplayType As ButtonDisplayEnum)
Create(displayName, internalName, description, tooltip, AddinGlobal.ClassId, standardIcon, largeIcon, commandType, buttonDisplayType)
End Sub
''' <summary>
''' The signature does not care about Command Type (always editing) and Button Display (always with text).
''' </summary>
Sub New(ByVal displayName As String, ByVal internalName As String, ByVal description As String, ByVal tooltip As String, ByVal standardIcon As Icon, ByVal largeIcon As Icon)
Create(displayName, internalName, description, tooltip, AddinGlobal.ClassId, Nothing, Nothing, CommandTypesEnum.kEditMaskCmdType, ButtonDisplayEnum.kAlwaysDisplayText)
End Sub
''' <summary>
''' The signature does not care about icons.
''' </summary>
Sub New(ByVal displayName As String, ByVal internalName As String, ByVal description As String, ByVal tooltip As String, ByVal commandType As CommandTypesEnum, ByVal buttonDisplayType As ButtonDisplayEnum)
Create(displayName, internalName, description, tooltip, AddinGlobal.ClassId, Nothing, Nothing, commandType, buttonDisplayType)
End Sub
''' <summary>
''' This signature only cares about display name and icons.
''' </summary>
''' <param name="displayName"></param>
''' <param name="standardIcon"></param>
''' <param name="largeIcon"></param>
Sub New(ByVal displayName As String, ByVal standardIcon As Icon, ByVal largeIcon As Icon)
Create(displayName, displayName, displayName, displayName, AddinGlobal.ClassId, standardIcon, largeIcon, CommandTypesEnum.kEditMaskCmdType, ButtonDisplayEnum.kAlwaysDisplayText)
End Sub
''' <summary>
''' The simplest signature, which can be good for prototyping.
''' </summary>
Sub New(ByVal displayName As String)
Create(displayName, displayName, displayName, displayName, AddinGlobal.ClassId, Nothing, Nothing, CommandTypesEnum.kEditMaskCmdType, ButtonDisplayEnum.kAlwaysDisplayText)
End Sub
''' <summary>
''' The helper method for constructors to call to avoid duplicate code.
''' </summary>
Public Sub Create(ByVal displayName As String, ByVal internalName As String, ByVal description As String, ByVal tooltip As String, ByVal clientId As String, ByVal standardIcon As Icon, ByVal largeIcon As Icon, ByVal commandType As CommandTypesEnum, ByVal buttonDisplayType As ButtonDisplayEnum)
If (String.IsNullOrEmpty(clientId)) Then
clientId = AddinGlobal.ClassId
Dim standardIconIPictureDisp As stdole.IPictureDisp = Nothing
Dim largeIconIPictureDisp As stdole.IPictureDisp = Nothing
If (standardIcon IsNot Nothing) Then
standardIconIPictureDisp = IconToPicture(standardIcon)
largeIconIPictureDisp = IconToPicture(largeIcon)
mButtonDef = AddinGlobal.InventorApp.CommandManager.ControlDefinitions.AddButtonDefinition(displayName, internalName, commandType, clientId, description, tooltip, standardIconIPictureDisp, largeIconIPictureDisp, buttonDisplayType)
mButtonDef.Enabled = True
AddHandler mButtonDef.OnExecute, AddressOf ButtonDefinition_OnExecute
DisplayText = True
AddinGlobal.ButtonList.Add(Me)
End Sub
#End Region
#Region "Behavior"
Public Property DisplayBigIcon As Boolean
Public Property DisplayText As Boolean
Public Property InsertBeforeTarget As Boolean
Public Sub SetBehavior(ByVal useBigIcon As Boolean, ByVal showText As Boolean, ByVal beforeTarget As Boolean)
DisplayBigIcon = useBigIcon
DisplayText = showText
InsertBeforeTarget = beforeTarget
End Sub
Public Sub CopyBehaviorFrom(ByVal button As InventorButton)
DisplayBigIcon = button.DisplayBigIcon
DisplayText = button.DisplayText
InsertBeforeTarget = InsertBeforeTarget
End Sub
#End Region
#Region "Actions"
''' <summary>
''' The button callback method.
''' </summary>
''' <param name="context"></param>
Private Sub ButtonDefinition_OnExecute(ByVal context As NameValueMap)
If (Execute IsNot Nothing) Then
Execute()
Else
MessageBox.Show("Nothing to execute.")
End Sub
''' <summary>
''' The button action to be assigned from anywhere outside.
''' </summary>
Public Execute As Action
#End Region
#Region "Image Converters"
Public Shared Function ImageToPicture(ByVal image As Image) As stdole.IPictureDisp
Return ImageConverter.ImageToPicture(image)
End Function
Public Shared Function IconToPicture(ByVal icon As Icon) As stdole.IPictureDisp
Return ImageConverter.ImageToPicture(icon.ToBitmap())
End Function
Public Shared Function PictureToImage(ByVal picture As stdole.IPictureDisp) As Image
Return ImageConverter.PictureToImage(picture)
End Function
Public Shared Function PictureToIcon(ByVal picture As stdole.IPictureDisp) As Icon
Return ImageConverter.PictureToIcon(picture)
End Function
Private Class ImageConverter
Inherits AxHost
Sub New()
MyBase.New(String.Empty)
End Sub
Return GetIPictureDispFromPicture(image)
End Function
Return ImageToPicture(icon.ToBitmap())
End Function
Return GetPictureFromIPicture(picture)
End Function
Dim bitmap As Bitmap = New Bitmap(PictureToImage(picture))
Return System.Drawing.Icon.FromHandle(bitmap.GetHicon())
End Function
End Class
#End Region
End Class
''' <summary>
''' This class is used to set the InventorWin as the owner of any WinForms.
''' Usage:
''' winform.Show(New InventorWin())
''' </summary>
Public Class InventorWin
Implements IWin32Window
Public ReadOnly Property Handle As IntPtr Implements IWin32Window.Handle
Get
Return AddinGlobal.InventorApp.MainFrameHWND
End Get
End Property
End Class
'End Namespace
ButtonActions Class
#Region "Namespaces"
Imports System
Imports Inventor
#End Region
Public Class ButtonActions
Public Shared Sub Button1_Execute()
Msgbox("Button 1 pressed")
End Sub
Public Shared Sub Button2_Execute()
Msgbox("Button 2 pressed")
End Sub
End Class
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
