Inventor commands list in iLogic
PiazzaD
PiazzaD
Hi, every now and then I need to look for the name of the Inventor commands "attached" to the ribbon to run them using the Execute/Execute2 methods.
So I finally decided to write few lines of iLogic code to dump and run the commands.
I though this might be of some help for others so I wrote a post and provided the code.
Here is the link (sorry is a business address):
http://www.qsinformatica.it/index.php?option=com_content&view=article&id=251:list-and-run-autodesk-i...
You can spend few hours looking for hidden commands in Inventor...
Smiley Wink
Very nice. Thanks
MechMachineMan
Hey Piazza! Looks like a pretty nifty routine.
Just curious - does it provide any information that this doesnt?
Sub Main()
Dim oControlDefs As ControlDefinitions
oControlDefs = ThisApplication.CommandManager.ControlDefinitions
Dim oControlDef As ControlDefinition
oWriteDoc = "C:\Windows\Temp\Command Names.txt"
oWrite = System.IO.File.CreateText(oWriteDoc)
For Each oControlDef In oControlDefs
oWrite.WriteLine(oControlDef.InternalName & " :: " & oControlDef.DescriptionText)
Next
oWrite.Close
ThisDoc.Launch(oWriteDoc)
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
PiazzaD
More or less the same. Just wanted to provide a GUI to list and run/test commands. Useful info are:
InternalName --> for execution
DisplayName --> for short description
DescriptionText --> for a detailed description (when available)
Daniele
