Inventor captures the input from the custom Form
arsenii_yavtushenko
arsenii_yavtushenko
The issue is that each time I get to create a form with TextBox in it, Inventor keeps capturing the space and enter buttons, thereby opening the identical copy of the already opened form. I looked everywhere but wasn't able to find a solution.
I am using Visual Studio 2012 Express and Inventor 2016, creating the form as an addin (with dll and addin files, not as a separate program).
I would appreciate any help, thank you!
bradeneuropeArthur
I don't understand your question really:
  • The issue is that each time I get to create a form with TextBox in it.
    Are you creating a new empty windows form each time or are you creating a custom form from your add-in?
  • Inventor keeps capturing the space and enter buttons. What do you mean with this?
  • thereby opening the identical copy of the already opened form. What do you mean with this?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
arsenii_yavtushenko
Thanks for the answer!
I recorded a video of what I mean. Each time I press Space, the new form pops up. I think it is because Inventor captures the input, and the Space button repeats the last command..
bradeneuropeArthur
Are you using:
Xform.show()
or
Xform.showdialog()
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
arsenii_yavtushenko
I have used Show() to show the form, after I've changed it to ShowDialog(), it all started to work properly!
Thank you very much!
