Check face participation in constraint
fakeru
fakeru
Hi all,
What would a good method to check if a given face (of occurrence) in assembly participates in a constraint?
Autodesk Inventor 2015 Certified Professional
JelteDeJong
You can loop over all constraint and check if one of the used entities is the face. some thing like this iLogic rule:
Dim face As Object = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllEntitiesFilter, "Select face")
Dim doc As AssemblyDocument = ThisDoc.Document
For Each constraint As AssemblyConstraint In doc.ComponentDefinition.Constraints
    If ((constraint.EntityOne.Equals(face)) Or (constraint.EntityTwo.Equals(face))) Then
        MsgBox("This face is in a constraint: " + constraint.Name)
Next
Jelte de Jong
Blog: hjalte.nl - github.com
fakeru
Thanks! I was kind of thinking about this. I didn't know the "Equals" can be used for that 🙂
I might also have to tweak the code so it looks into subassemblies constraints. Basically I need to check for constraints at any assembly level.
