Inventor API: How to Advise BrowserPane-Events
Hi @Anonymous
I'm looking for a useable possibility to catch the OnActivate event of a BrowserPane.
BrowserPane events seem to be some different then the other typical Inventor EventSink's.
Can anybody give me any hint or example how to advise and catch BrowserPane events?
Thanks a lot in advance...
Chris
MechMachineMan
Yes.
Read this thread:
https://forums.autodesk.com/t5/inventor-customization/quick-idea-to-run-ilogic-rule-on-view-represen...
Then go to the API resources and look for a similar command that applies to visibility changes..
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
