INVENTOR API - GET THE SOLID RANGEBOX IN PART ENVIRONMENT
Khoa_NguyenDang
Khoa_NguyenDang
HI all guy
Does anybody know how to get the rangbox size of solid with API
I want to get the rangebox size for Solid in Part Environment, but I have no idea
If anyone knows it, hope you can help me.
Thank you so much
Michael.Navara
Try this code for begining
Dim part As PartDocument = ThisDoc.Document
Dim partDef As PartComponentDefinition = part.ComponentDefinition
Dim rangeBox As Box = Nothing
For Each sBody As SurfaceBody In partDef.SurfaceBodies
	If rangeBox Is Nothing Then
		rangeBox = sBody.RangeBox
	Else
		Dim bodyRangeBox = sBody.RangeBox
		rangeBox.Extend(bodyRangeBox.MinPoint)
		rangeBox.Extend(bodyRangeBox.MaxPoint)
	End If
Next
Dim x = rangeBox.MaxPoint.X - rangeBox.MinPoint.X
Dim y = rangeBox.MaxPoint.Y - rangeBox.MinPoint.Y
Dim z = rangeBox.MaxPoint.Z - rangeBox.MinPoint.Z
MsgBox(String.Format("{0:N2} x {1:N2} x {2:N2} [cm]", x, y, z))
bradeneuropeArthur
I can send you the code later. Hang on.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Khoa_NguyenDang
HI @Michael.Navara
Thank you so much, now i can do it
