Inventor Add-in Templates for 2017
ngocson8335
ngocson8335
Dear Autodesk Expert,
I am using Add-In Template for Inventor 2018. But I would like to install for Inventor 2017.  Please help me to change something in this template to install in 2017.
Nice day!
Thank you so much.
Ngoc Son - Autodesk Inventor User
Ngoc Son
Autodesk User
bradeneuropeArthur
First change your reference for the Autodesk Inventor Object Library form 2018 version to inventor 2017 version.
Like this:
C:\Windows\Microsoft.NET\assembly\GAC_MSIL\Autodesk.Inventor.Interop\v4.0_########\autodesk.inventor.interop.dll
Than take a look if there are errors.
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Martin-Winkler-Consulting
@ngocson8335
In my experience I can say that addins created with a higher version of Inventor also run on lower versions. Unless you are using a functionality that did not exist in the lower version yet.
Regards Martin
Martin Winkler
CAD Developer
Did you find this post helpful? Feel free to like this post.
ngocson8335
Dear Mr.bradeneurope|Arthur
I already changed to the Autodesk Inventor Object Library form 2017 and I didn't see any errors, but when Inventor 2017 launched it didn't load the add-in.
Please see my attached project (.zip).
Ngoc Son
Autodesk User
@ngocson8335
you have to change the Autodesk.iFeatureName.Inventor.addin File for loading lower versions:
<Addin Type="Standard">
  <!--Created for Autodesk Inventor 2018 (Version 22.0)-->
  <ClassId>{de55ae5b-65de-4465-bbb5-d1617c2ccc9f}</ClassId>
  <ClientId>{de55ae5b-65de-4465-bbb5-d1617c2ccc9f}</ClientId>
  <DisplayName>iFeatureName</DisplayName>
  <Description>iFeatureName</Description>
  <Assembly>iFeatureName.dll</Assembly>
  <LoadOnStartUp>1</LoadOnStartUp>
  <UserUnloadable>1</UserUnloadable>
  <Hidden>0</Hidden>
  <SupportedSoftwareVersionGreaterThan>20..</SupportedSoftwareVersionGreaterThan>
  <DataVersion>1</DataVersion>
  <UserInterfaceVersion>1</UserInterfaceVersion>
</Addin>
Please additionally check if the addin files are in the directory C:\ProgramData\Autodesk\ApplicationPlugins\ located.
Regards
Martin
Martin Winkler
CAD Developer
ngocson8335
Dear Mr.
Thank you so much. It works very well. I tried to do the same your way before and now it didn't work until I restarted my computer.
Thanks thanks thanks Sir!!!
Ngoc Son
Autodesk User
