Publish DXF from Part Setting ACAD Version
Martin-Winkler-Consulting
Advisor Advisor
Hi, i am publishing a selected face from a normal part with the API to a dxf File. I am using this code because doing it with an ini File does not works in this context (it's not a SheetMetal Part):
    Dim Cm As CommandManager = InventorApp.CommandManager
                    Cm.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, mPath.ToString)
                    Dim oCtrlDef As ButtonDefinition = Cm.ControlDefinitions.Item("GeomToDXFCommand")
                    oCtrlDef.Execute()
This works, but i would like to set the Version of ACAD for the dxf File. Is there a possibility to do this with the API?
Regards Martin
Martin Winkler
CAD Developer
Did you find this post helpful? Feel free to like this post.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Martin-Winkler-Consulting ,
It is unfortunate that Inventor API does not support to export face with ACAD versions. Please log this wish list at idea station using below link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
