Inventor Add in Publish to MSI or exe
Stryder33345
Message 1 of 9
Stryder33345
Hi All I have recently completed an addin for inventor and I am ready to deploy the program for use in my work for further testing. Can anyone tell me or give me a link to how I can publish my addin to an .msi or .exe file for deployment using Visual Studio Community 2015 ? Thanks in Advance Ben Inventor 2016 Visual Studio Community 2015
Replies (8)
Message 2 of 9
pball
I'm actually using a self extracting 7zip archive to install my addin. It works well for me. If you're open to try this I can post detailed instructions.
If you need an msi or real exe installer I can't help out.
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
Message 3 of 9
Stryder33345
Thanks for the reply, Im up for trying that for now.
Message 4 of 9
pball
Here is how I make a 7zip self extracting archive.
General instructions on making a 7zip sfx archive
http://www.region3dfg.org/comp/7zipsfx
My personal config file
;!@Install@!UTF-8!
Title="MISC Addin"
BeginPrompt="Do you want to install MISC Addin v0.1.1?"
FinishMessage="Finished installing MISC Addin"
InstallPath="%appdata%\Autodesk\ApplicationPlugins\MISC"
OverwriteMode="0"
GUIMode="2"
;!@InstallEnd@
Batch script to make creating the exe easier
@echo off
"C:\Program Files\7-Zip\7z.exe" a -t7z MISC_Addin.7z Autodesk.MISC.Inventor.addin MISC.dll
echo.
copy /b 7zsd.sfx + config.txt + MISC_Addin.7z MISC_Addin.exe
echo.
del MISC_Addin.7z
pause
If you have any specific questions let me know.
NOTE: Newer versions of 7-zip don't include the 7zsd.sfx file, get version 9.20
https://www.7-zip.org/a/7z920_extra.7z
Message 5 of 9
Rahul.Khande
Thank you !!
Message 6 of 9
jose_loaiza5W6L6
Hello
Im trying to do these steps however I have an error, the file 7zsd.sfx not found, anyone can help me? how can I generate this file?
Thank you
Message 7 of 9
bradeneuropeArthur
I use "Inno Setup Compiler" to create my installers...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 8 of 9
pball
@jose_loaiza5W6L6
Newer versions of 7zip seem to have removed 7zsd.sfx for some reason. 7-Zip 9.20 is the newest version with the required files. There is a direct link below or you can look for version 9.20. I personally keep a copy of 9.20 just for creating install files and use a more recent version for everyday tasks.
Message 9 of 9
jose_loaiza5W6L6
Thank you so much, for your help, that was I needed.
