Drawing Note box size
bwang-tecoustics
bwang-tecoustics
When you pick a drawing note on the sheet, it shows 8 green dots around the notes. Is there a way to get the size of this box from VB? Or where I can find the VB reference for drawing GeneralNote?
Copy and pasted from the VBA API Help file.
DrawingNote.RangeBox Property
Parent Object: DrawingNote
Description
Property that returns a Box2D object which contains the lower-left and upper-right corners of a rectangle that is guaranteed to enclose this object.
Syntax
DrawingNote.RangeBox() As Box2d
Version
Introduced in Inventor version 2010
Also from the VBA editor you can go to the view menu and choose object browser. From there you can right click and look up the help files for everything.
bwang-tecoustics
Perfect, this really helps. Thx.
No problem, glad to help! Thanks for the Kudos.
