Inventor 2018 -Frame Generator [custom shape creation BOM issues]
dbarber35H2H
Observer Observer
dbarber35H2H
Observer
Observer
Need some help with property mapping when creating new structural shapes for frame generator library.  I have successfully created new shapes but the driven length is no longer being populated in the part number field and I cannot get a streamlined cut list like using default library shapes.Capture.JPG
bradeneuropeArthur
check your table in the Content Center Editor.
Check if all values are black from top till bottom, ohterwise these are overwritten.
In the column properties the correct value is populated, but not for the blue listed rows and columns,
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
