iLogic to add "FOR BOM SEE SHT #" on the title block of every sheet without BOM?
claudio.ibarra
claudio.ibarra
Whenever the rule runs, it looks at all the sheets for a parts list. Then modify a block of text in the title block as such:
0 sheets with parts list --> no sheets have the "FOR BOM SEE SHT #" displayed. Looks like nothing happens.
1 sheet with parts list --> That sheet would have the note hidden, but every other sheet would have "FOR BOM SEE SHT #" to point the reader to the correct sheet.
Several sheets with parts list --> All sheets have "FOR BOM SEE SHT # & # & ..."  (this will almost never happen)
Is that possible with an iLogic rule that runs on the drawing template?
chandra.shekar.g
Autodesk Support
Autodesk Support
@claudio.ibarra,
Please provide non confidential input drawing and result drawing to generate iLogic code.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
bradeneuropeArthur
@claudio.ibarra
Please provide us the drawing Border and Header!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
claudio.ibarra
@chandra.shekar.g wrote:
@claudio.ibarra,
Thanks and regards,
Any drawing -- the default template, with an added text box. Can you reference the sheet number the Bill of Materials is on with some <> type reference? Can it point to a variable that can be populated by the number(s) of the sheet(s) which contains the Bill of Materials?
claudio.ibarra
@bradeneuropeArthur wrote:
@claudio.ibarra
