Inventor 2015 iLogic Sheet Properties
Message 1 of 18
Hi all,
I am having some issues solving a problem which I have been racking my brain over for almost a year with nothing to show for it.
I am trying to create an iLogic script to either directly edit the "Sheet Revision" property or open a form where it can be modified. I use this property in my Title Blocks as we do per-sheet revisions of our drawings.
I have tried playing with the Drawing and Advanced Drawing API functions, but have had no luck finding the correct iLogic code to access the property.
I already use an iLogic form that triggers on "New Drawing" to input the drawing number, author, etc. iProperties we use in our Title Blocks, but these exist on a per-drawing not a per-sheet basis. For the per-sheet data we use Prompted Entry normally, however I am stubborn and want to set the Sheet Revision number using the property.
On another note, does anyone know how to get an iLogic rule to run when the active sheet changes?
Thanks in advance for your responses,
Erik
Replies (17)
Message 2 of 18
Mark.Lancaster
@Anonymous
iLogic programming questions and issue should be posted in the Inventor Customization forum to receive the best results.  I will have the moderator relocate your posting there to best suit your needs.
https://forums.autodesk.com/t5/inventor-customization/bd-p/120
Mark Lancaster
Message 3 of 18
dgreatice
try this :
SheetRev = InputBox("Input Sheet Revision", "Sheet Revision", ActiveSheet.Sheet.Revision)
ActiveSheet.Sheet.Revision = SheetRev
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 4 of 18
No dice. Spits out the following error:
Error in rule: Revision, in document: test.idw
Public member 'Revision' on type 'Sheet' not found.
Message 5 of 18
dgreatice
ok, lets modify that code:
Dim oDD As DrawingDocument
Dim oSht As Sheet
oDD = ThisApplication.ActiveDocument
oSht = oDD.ActiveSheet
SheetRev = InputBox("Input Sheet Revision", "Sheet Revision", oSht.Revision)
oSht.Revision = SheetRev
Message 6 of 18
Same error. Inventor 2015 doesn't seem to be seeing the 'Revision' parameter attached to the sheet object.
Message 7 of 18
dgreatice
can you check using VBA inside inventor 2015?
Message 8 of 18
This is how it is configured:
It is now producing this error:
Message 9 of 18
Sorry, misread you previous reply. I haven't used VBA in Inventor before.
Am i just running your code as a macro? Or am I completely oblivious to something obvious?
Message 10 of 18
dgreatice
Uncheck list Straight VB Code.
try to run rule again
Message 11 of 18
Both of the posted codes work in Inventor Pro 2018 (Student Version), but neither worked in 2015 (with Straight VB code enabled or disabled)
I was getting both the same error as before, and another error about improper declaration.
Message 12 of 18
bradeneuropeArthur
Dim oDD As inventor.DrawingDocument
Dim oSht As inventor.Sheet
Dim SheetRev as String
For VBA:
Public Sub nn()
Dim oDD As Inventor.DrawingDocument
Dim oSht As Inventor.Sheet
Set oDD = ThisApplication.ActiveDocument
Set oSht = oDD.ActiveSheet
Dim SheetRev As String
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 13 of 18
Still puts out the following error in 2015:
System.MissingMemberException: Public member 'Revision' on type 'Sheet' not found.
   at Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack)
   at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
   at LmiRuleScript.Main()
   at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
   at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Yet, it works in 2018...
And trying in VBA:
Message 14 of 18
bradeneuropeArthur
try this:
for I-logic:
Public Sub nn()
SheetRev = InputBox("Input Sheet Revision", "Sheet Revision")
End Sub
for Vba:
Public Sub nn()
End Sub
Are you getting the inputbox now?
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 15 of 18
Had to change the sub name to main, but the input box now shows, but the same error still shows after closing the dialogue:
   at Microsoft.VisualBasic.CompilerServices.LateBinding.InternalLateSet(Object o, Type& objType, String name, Object[] args, String[] paramnames, Boolean OptimisticSet, CallType UseCallType)
   at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateSet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean OptimisticSet, Boolean RValueBase, CallType CallType)
 When trying in VBA the input box shows then is throws this error:
Message 16 of 18
bradeneuropeArthur
Have you set all references correctly for VBA:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 17 of 18
Yes, the references are set.
Message 18 of 18
mseveroLXMQ8
Works great!
