Inserting a balloon that has a field for prompted text
10:43 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I would like to make a split balloon where the top retrieves the item number and the bottom is a prompted text area. Is this possible?
If the above is not possible my fallback plan would like to make a sketched symbol function in exactly the same way. I believe this option would be significantly more code. If I have to go this route, is there a way to directly mimick getting the item number like the balloon function does?
--My current process involves attacghing a user symbol, getting the proper leader node, attached entity, geometry, model geometry, containing occurrence, and then BOM of the component occurrence. Keep in mind this doesn't work for phantom or reference components. There must be a better way.
