ilogic sketched symbol with leader
I trying to insert a symbol with a leader but i have a error message after de step 6, anybody can help me
with this code?
the code
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
' Set a reference to the active sheet.
Dim oActiveSheet As Sheet
oActiveSheet = oDrawDoc.ActiveSheet
' Set a reference to the drawing curve segment.
' This assumes that a drawing curve is selected.
Dim oDrawingCurveSegment As DrawingCurveSegment
oDrawingCurveSegment = oDrawDoc.SelectSet.Item(1)
' Set a reference to the drawing curve.
Dim oDrawingCurve As DrawingCurve
oDrawingCurve = oDrawingCurveSegment.Parent
' Get the mid point of the selected curve
' assuming that the selection curve is linear
Dim oMidPoint As Point2d
oMidPoint = oDrawingCurve.MidPoint
' Set a reference to the TransientGeometry object.
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
Dim oLeaderPoints As ObjectCollection
oLeaderPoints =
ThisApplication.TransientObjects.CreateObjectCollection
' Create a few leader points.
Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X, oMidPoint.Y))
' Create an intent and add to the leader points collection.
' This is the geometry that the symbol will attach to.
Dim oGeometryIntent As GeometryIntent
oGeometryIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve)
Call oLeaderPoints.Add(oGeometryIntent)
' Get the first symbol definition
Dim oSketchSymDef As SketchedSymbolDefinition
oSketchSymDef = oDrawDoc.SketchedSymbolDefinitions.Item("View_Label")
MessageBox.Show("6", "STEP")
' Create the symbol with a leader
Dim oSketchedSymbol As SketchedSymbol
oSketchedSymbol = oActiveSheet.SketchedSymbols.AddWithLeader(oSketchSymDef,oLeaderPoints)
the error message
Thanks for you help!
ok i find the solution in api programming help and insert this code before her code
Dim doc = ThisApplication.ActiveDocument
Dim entity = ThisApplication.CommandManager.Pick(
SelectionFilterEnum.kDrawingCurveSegmentFilter,
"select line")
my problem now is the insertion point of the narrow leader, i want to insert the leader in the middle of the line, anybody know to make that???
this is the complet code
"select line")
' This assumes that a drwaing curve is selected.
oDrawingCurveSegment = entity
oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection
Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X, oMidPoint.Y - 1.8))
Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X, oMidPoint.Y - 1.8 ))
oSketchSymDef = oDrawDoc.SketchedSymbolDefinitions.Item("test leader")
oSketchedSymbol = oActiveSheet.SketchedSymbols.AddWithLeader(oSketchSymDef, oLeaderPoints)
I ADD oSketchedSymbol.LeaderVisible = False at the bottom of the rule
i have new problem with my rule if i add  a Prompted Entry text in my symbol my rule dont work
and show me this error message? if i delete this new entry, work again???
Vladimir.Ananyev
Could this link help you with format for prompted text?
http://forums.autodesk.com/t5/Inventor-Customization/Sample-Code-does-not-work/m-p/4542347/highlight...
If not then please post your test for propmped text that could be analyzed.
cheers
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Thanks for your help Vladimir 🙂
Maybe i find the solution one day 🙂
