insert sketch symbol from a part property
Miguel.CarvajalS34Q6
hi, alls.
I have a need, when I built a part in the part module I give it a property called roughness, and it is linked to the surface finish, this property has a list of variables that I can select from a form in the part, I want When inserting the part on the drawing sheet, a block that has the same name as the property variable is automatically inserted. and that according to the size of the sheet where it is inserted, the coordinates change so that the block is always in the same position with respect to the box.
thank you for your assistance
bradeneuropeArthur
Do you prefer I-Logic; or a Add-in.
I prefer doing it with a Add-in Via vb.net.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
