iLogice rule to fill our iProperties from Microsof Excel file
Message 1 of 9
Hello, I am very new to iLogic, but have been interested in getting to know it better.  I am trying to write a piece of code that will allow me to pull information from an excel file and insert that into the iProperties for the part specified.  the excel file is very simple and in the first row the columns read as follows: PART NUMBER, DESCRIPTION, PROJECT, TITLE
I have got the code to read from the file, but it only fills out the iProperties on the part with information listed from the first part on the list in the excel file.
part_number = InputBox("Plese enter the part number", "Get Data")
i = GoExcel.FindRow("C:\LSE Vault\Data\iProperties_new.xlsx", "Sheet1", "PART NUMBER", "=", part_number, "DESCRIPTION", "=", part_description, "PROJECT", "=", part_project, "TITLE", "=", part_title)
part_description = GoExcel.CurrentRowValue("DESCRIPTION")
part_project = GoExcel.CurrentRowValue("PROJECT")
part_title = GoExcel.CurrentRowValue("TITLE")
iProperties.Value("Project", "Part Number") = part_number
iProperties.Value("Project", "Description") = part_description
iProperties.Value("Project", "Project") = part_project
iProperties.Value("Summary", "Title") = part_title
MessageBox.Show("All properties have been applied to " & part_number, "Success")
Replies (8)
Message 2 of 9
bradeneuropeArthur
could you provide the Excel file for testing?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 9
Message 4 of 9
clutsa
My guess is you need to not have all the extra lookup data for the row.
i = GoExcel.FindRow("C:\LSE Vault\Data\iProperties_new.xlsx", "Sheet1", "PART NUMBER", "=", part_number)
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
Message 5 of 9
bradeneuropeArthur
i = GoExcel.FindRow("C:\Vault\Projects\Forum\iProperties_new.xlsx", "Sheet1", "PART NUMBER", "=", part_number)
'i = GoExcel.FindRow("C:\Vault\Projects\Forum\iProperties_new.xlsx", "Sheet1", "PART NUMBER", "=", "0003", "DESCRIPTION", "=", part_description, "PROJECT", "=", part_project, "TITLE", "=", part_title)
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 9
Sergio.D.Suárez
I have tried it, and it has worked for me, it has a variable to test if the values of the excel table are empty, not to search in all the excel cells and only those in the table.
I hope it works for you. regards
Dim Dirxlsx As String = "C:\LSE Vault\Data\iProperties_new.xlsx"
Dim osheetbom As String = "Sheet1"
xlApp = CreateObject("Excel.Application")
xlApp.Visible = True
xlWorkbook = xlApp.Workbooks.Open(Dirxlsx)
xlWorksheet = xlWorkbook.Worksheets.Item(osheetbom)
Dim j As Integer = 1
Line1 :
oTest = xlWorksheet.Range("A" & j).Value
If oTest <> "" Then
	j = j + 1
	GoTo Line1
For row = 2 To j
	If xlWorksheet.Range("A" & Row).Value = part_number Then
		iProperties.Value("Project", "Part Number") = xlWorksheet.Range("A" & Row).Value
		iProperties.Value("Project", "Description") = xlWorksheet.Range("B" & Row).Value
		iProperties.Value("Project", "Project") = xlWorksheet.Range("C" & Row).Value
		iProperties.Value("Summary", "Title") = xlWorksheet.Range("D" & Row).Value
		MessageBox.Show("All properties have been applied", "Success")
Next
xlWorkbook.Close (True)
xlApp.Quit
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 7 of 9
bradeneuropeArthur
@clutsa
That was close!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 9
Thank you! That works great! My next step is to figure out how to apply a rule like this to an assembly drawing and import properties to each part if the properties have yet to be established.  Do you have any advice on what I might look into to point me in the right direction?
Message 9 of 9
clutsa
@bradeneuropeArthur Right! I feel robbed!Smiley Tongue I dropped a "Dim part_number as string" and ran this on an part file with the spreadsheet embedded and it works fine. If I hadn't had a dentist appointment I could have tested it before I posted. Some days man.Smiley Frustrated
Dim part_number As String
i = GoExcel.FindRow("iProperties_new.xlsx", "Sheet1", "PART NUMBER", "=", part_number)
