iLogic code to pull iProperties from Microsoft excel file
Hello, I am very new to iLogic, but have been interested in getting to know it better.  I am trying to write a piece of code that will allow me to pull information from an excel file and insert that into the iProperties for the part specified.  the excel file is very simple and in the first row the columns read as follows: PART NUMBER, DESCRIPTION, PROJECT, TITLE
I have got the code to read from the file, but it only fills out the iProperties on the part with information listed from the first part on the list in the excel file.
part_number = InputBox("Plese enter the part number", "Get Data")
i = GoExcel.FindRow("C:\LSE Vault\Data\iProperties_new.xlsx", "Sheet1", "PART NUMBER", "=", part_number, "DESCRIPTION", "=", part_description, "PROJECT", "=", part_project, "TITLE", "=", part_title)
part_description = GoExcel.CurrentRowValue("DESCRIPTION")
part_project = GoExcel.CurrentRowValue("PROJECT")
part_title = GoExcel.CurrentRowValue("TITLE")
iProperties.Value("Project", "Part Number") = part_number
iProperties.Value("Project", "Description") = part_description
iProperties.Value("Project", "Project") = part_project
iProperties.Value("Summary", "Title") = part_title
MessageBox.Show("All properties have been applied to " & part_number, "Success")
Mark.Lancaster
@Anonymous
Programming needs should be asked in the Inventor customization for best results.  https://forums.autodesk.com/t5/inventor-customization/bd-p/120
I will have the moderator relocate your posting there to best suit your needs.
Mark Lancaster
Sergio.D.Suárez
Hi, Try this code I have not tried it, but I think it should work. regards
Dim Dirxlsx As String = "C:\LSE Vault\Data\iProperties_new.xlsx"
Dim osheetbom As String = "Sheet1"
xlApp = CreateObject("Excel.Application")
xlApp.Visible = True
xlWorkbook = xlApp.Workbooks.Open(Dirxlsx)
xlWorksheet = xlWorkbook.Worksheets.Item(osheetbom)
Dim row As Integer = 2                 ''' Indicate from which row the copying will start to excel
iProperties.Value("Project", "Part Number") = xlWorksheet.Range("A" & row).Value iProperties.Value("Project", "Description") = xlWorksheet.Range("B" & row).Value iProperties.Value("Project", "Project") = xlWorksheet.Range("C" & row).Value iProperties.Value("Summary", "Title") = xlWorksheet.Range("D" & row).Value MessageBox.Show("All properties have been applied", "Success") xlWorkbook.Close (True) xlApp.Quit
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Thank you, this does work, however I do not want just the second row to be the constant value. I want to enter the part number and the rule pull the information from the specific row the part number is in
Sergio.D.Suárez
Try the following code, maybe it should work. In a moment I will prove it. regards
Dim j As Integer = 1
Line1 :
oTest = xlWorksheet.Range("A" & j).Value
If oTest <> "" Then
	j = j + 1
	GoTo Line1
For row = 2 To j
	If xlWorksheet.Range("A" & Row).Value = part_number Then
		iProperties.Value("Project", "Part Number") = xlWorksheet.Range("A" & Row).Value
		iProperties.Value("Project", "Description") = xlWorksheet.Range("B" & Row).Value
		iProperties.Value("Project", "Project") = xlWorksheet.Range("C" & Row).Value
		iProperties.Value("Summary", "Title") = xlWorksheet.Range("D" & Row).Value
Next
xlApp.Quit
Mechanical Designer
