Running iLogic rules in order
I'm just wondering exactly how rules run in iLogic. I am using the following code:
ThisAssembly.BeginManage("Support")
If Support_Type = "A"
	Components.Add("Beam", "Support A.ipt")
	Components.Add("Back Plate", "Back Plate.ipt")
	iLogicVb.RunRule("Support A")
ElseIf Support_Type = "B"
	Components.Add("Beam", "Support B.ipt")
	Components.Add("Flange", "Flange.ipt")
	Components.Add("Channel", "Channel.ipt")
	iLogicVb.RunRule("Support B")
	Patterns.AddRectangular("Flange Pattern", "Flange", Flange_N + 1 ul, Flange_ActP, "Flange", "Pattern Edge")
ThisAssembly.EndManage("Support")
 The "Support B" rule outputs the inputs for the rectangular pattern "Flange Pattern", but I always have to run the rule twice for it to update correctly. How do I write my code so the pattern is not made until the "Support B" rule has finished running and the parameters have been updated?
CCarreiras
Hi!
Try to update the model before using the pattern.
insert this line before the pattern command
InventorVb.DocumentUpdate()
CCarreiras
Sergio.D.Suárez
Hello, I have found that in a series of ilogic shortcuts I must execute as your rule twice so that it is actually executed. Then I had to use another form of access or add a loop.
When you execute the rule twice the result is fine?
Do not duplicate the added components?
regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
I have tried document and parameter updates. They don't seem to work.
regards
It does work when I run the rule twice, but is there not a better solution to this?
The added components are different files. They are referred to by the same name, but only one is active at a time.
Sergio.D.Suárez
It would not be ideal. It would be necessary to study the archives and the accesses to the properties.
However, I think a loop could work like the following
For i As Integer = 1 To 2
	MessageBox.Show("Example")
next
Adapted to your problem would be
Next
I hope this can help something. regards
Mechanical Designer
