ILogic vs API Model Property access via Drawing
kmiller
kmiller
I have done some searching and will continue to look, but is there an easy way to get this illogic code to work in .net addin?  I have having a trouble finding a way to easily pull the model information of the drawing document and setting my ipropery value (in my drawing) to use the "DocName, iprop set name, iprop name" arguments.
- Partial I Logic code below -
 'Exit rule if no part or assembly is in the drawing yet.
 If (ThisDrawing.ModelDocument Is Nothing) Then
   Return
  Else
   'Get the filename of the doc the drawing points to
   modelName = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
    iProperties.Value("Custom", "InvTic_ActPcSqFt") = iProperties.Value(modelName, "Custom", "Tic_ActualSqFt")
I can't find in the API where I can grab the Drawing.ModelDocument and be able to use that document to set the value to the iproperties.  I guess I am wondering if these methods are even available in the API or if they are only iLogic specific and/or if they are in the API where can I find them?
Otherwise it looked like there where some other posts I could try in regards to the drawing views.
The other option I had was just to keep our illogic code and potentially call that from my addin.  However, if I just build it into my addin, then we wouldn't need the illogic portion of it.
If this response answers your question please click "Accept as Solution".
MechMachineMan
The model document command through iLogic is the "same" as either of the 2 cases (not sure which)
- Grabbing the first REFERENCED DOCUMENT of the .idw
- Grabbing the first REFERENCED DOCUMENT of the first drawing view in the document
There are many, many samples, and the documentation does exist in the online programming help.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
kmiller
Perfect. Thanks for the tip.
