create iLogic mate using iMate
jzcrouse
jzcrouse
I am trying to insert a component into an assembly then constrain them using imates already on the component. I am able to insert the components however the imates that are on the component do not appear in the assembly. Here is the code that brings the part into my assembly. Seems like this should be straight forward since its directly from the API manual.
 SyntaxEditor Code Snippet
Public Sub Main()
    ' Get the component definition of the currently open assembly.
    ' This will fail if an assembly document is not open.
    Dim oAsmCompDef As AssemblyComponentDefinition
     oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
    ' Create a new matrix object.  It will be initialized to an identity matrix.
    Dim oMatrix As Matrix
     oMatrix = ThisApplication.TransientGeometry.CreateMatrix
    ' Place the first occurrence.
    Dim oOcc1 As ComponentOccurrence
     oOcc1 = oAsmCompDef.Occurrences.Add("C:\Vault Workspace\Designs\_Part Library\MSC - Miscellaneous\MSC.000001022.ipt", oMatrix)
    ' Place the second occurrence, but adjust the matrix slightly so they're
    ' not right on top of each other.
    oMatrix.Cell(1, 4) = 10
    Dim oOcc2 As ComponentOccurrence
     oOcc2 = oAsmCompDef.Occurrences.Add("C:\Vault Workspace\Designs\_Part Library\MSC - Miscellaneous\MSC.000001022.ipt", oMatrix)
    ' Look through the iMateDefinitions defined for the first occurrence
    ' and find the one named "iMate:1".  This loop demonstrates using the
    ' Count and Item properties of the iMateDefinitions object.
    Dim i As Long
    Dim oiMateDef1 As iMateDefinition
    For i = 1 To oOcc1.iMateDefinitions.Count
        If oOcc1.iMateDefinitions.Item(i).Name = "iMate:1" Then
             oiMateDef1 = oOcc1.iMateDefinitions.Item(i)
            Exit For
    Next
    If oiMateDef1 Is Nothing Then
        MsgBox ("An iMate definition named ""iMate:1"" does not exist in " & oOcc1.Name)
        Exit Sub
    ' Look through the iMateDefinitions defined for the second occurrence
    ' For Each method of iterating through a collection.
    Dim oiMateDef2 As iMateDefinition
    Dim bFoundDefinition As Boolean
    For Each oiMateDef2 In oOcc2.iMateDefinitions
        If oiMateDef2.Name = "iMate:2" Then
            bFoundDefinition = True
            Exit For
    Next
    If Not bFoundDefinition Then
        MsgBox ("An iMate definition named ""iMate:2"" does not exist in " & oOcc2.Name)
        Exit Sub
    ' Create an iMate result using the two definitions.
    Dim oiMateResult As iMateResult
     oiMateResult = oAsmCompDef.iMateResults.AddByTwoiMates(oiMateDef1, oiMateDef2)
End Sub
jzcrouse
nevermind figured it out. the imates werent included in the ipart
