Ilogic - unable to see new external rule in iLogic browser
I tried to add new external rule to standard path (located on the server disk). The rule was created (i saw it in Windows explorer), but it was not displayed in the left ilogic tree. Because of that I am unable to edit it. I see the other rules, but without the newly added rule. Other rules were created normally in this version of Inventor.
Chyba inventor.pngWhen I tried to add the rule to different directory (manually added rules), everything worked just fine.
I am using the Autodesk Inventor Profiesional 2019 Build 136
What should I do to solve this?
Thank you for any help!
Dan
I restarted windows and it helped. Now I am able to see and edit the newly added rule.
bradeneuropeArthur
So this is solved then?
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Not 100% sure. But I suppose that yes, it is solved. I will mark it as answered. I just restarted windows, started Inventor and then I saw the newly added rules.
bradeneuropeArthur
maybe check these settings:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
