iLogic to VBA Creation Date .idw
How can i convert this iLogic code to VBA? i want to change .idw files Creation Date NOW with VBA code.
File-iproperties-creation date- NOW
Could you please help me? or which VBA code should i use?
oTime = Now.ToShortDateString
iProperties.Value("Project", "Creation Date") = oTime
iLogicVb.UpdateWhenDone = True
End Sub
bradeneuropeArthur
Public Sub main()
'Dim oTime As String
'oTime = Now
''oTime.
Dim LValue As String
LValue = Format(Now, "dd/MMM/yy")
MsgBox LValue
MsgBox ThisDocument.PropertySets.Item(3).Item("Creation Time").Value
ThisDocument.PropertySets.Item(3).Item("Creation Time").Value = LValue
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Thanks for reply. It appears only a message  when i run the VBA code. It can not change the .idw files' creaton date. Long way to change the creaton date is : FILE-IPROPERTIES-PROJECT-CREATON DATE-NOW I want it to change with VBA code.
bradeneuropeArthur
Don't understand your last message!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
I want to change the creation date with VBA code at below picture.
