ilogic to save sheets to "AutoCAD 2000/LT 2000 DXF" with model geometry only
wobke11
wobke11
I've been able to copy codes from other people to create the following code which saves all sheets to DXF with filename_sheetname
I'm unsure whether its possible but I want the save copy as to be the file format "AutoCAD 2000/LT 2000 DXF" with model geometry only
Sub Save_As_DXF
	' Get the DXF translator Add-In.
	Dim DXFAddIn As TranslatorAddIn
	DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
	'Set a reference to the active document (the document to be published).
	Dim oDocument As Document
	oDocument = ThisApplication.ActiveDocument
	Dim oContext As TranslationContext
	oContext = ThisApplication.TransientObjects.CreateTranslationContext
	oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	' Create a NameValueMap object
	Dim oOptions As NameValueMap
	oOptions = ThisApplication.TransientObjects.CreateNameValueMap
	' Create a DataMedium object
	Dim oDataMedium As DataMedium
	oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
		'Gets the Workspace Path
		WorkspacePath= ThisDoc.WorkspacePath()
		'Gets the Length of the WorkspacePath String
		WorkspacePathLength = Len(WorkspacePath)
		'Gets just the Path of the file
		PathOnly = ThisDoc.Path
		'Removes the Workspace Path from FullPath
		DirectoryPath = Strings.Right(PathOnly, PathOnly.Length-WorkspacePathLength)
	' Sets directory for file save
	Dim DXFDirectory As String
	DXFDirectory = "P:\" & DirectoryPath
	' Sets save name as iProperties value
	Dim SaveName As String
	SaveName = DXFDirectory & "\" &ThisDoc.FileName(False)  & ".dxf"	'iProperties.Value("Project", "Part Number")    ThisDoc.FileName(False)
	If Len(Dir(DXFDirectory, vbDirectory)) = 0 Then
		MkDir (DXFDirectory)
	End If
	' Check whether the translator has 'SaveCopyAs' options
	If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
	Dim strIniFile As String
	strIniFile = "\\HMI-ENGINEERING\Inventor_Data\Miscellaneous\dxf.ini"
	' Create the name-value that specifies the ini file to use.
	oOptions.Value("Export_Acad_IniFile") = strIniFile
	End If
	'Set the destination file name
	oDataMedium.FileName = SaveName 'DXFDirectory && ".dxf"
	'Publish document.
	DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
	'Launch the dxf file in whatever application Windows is set to open this document type with
'	i = MessageBox.Show("Preview the DXF file?", "DXF Preview",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
'	If i = vbYes Then ThisDoc.Launch(oDataMedium.FileName)
End Sub
JelteDeJong
if im not mistaken you should be able to set it all in the ini file:
Jelte de Jong
Blog: hjalte.nl - github.com
wobke11
Ah yes you are correct, thank you.
I'm unable to change the ini file defined in the ilogic code though:
I've tried editing the exportdwg in public documents and it is giving me a dxf with model geometry only, but the problem is that it would not work on all the other computer without changing that ini file on all of them then...
C:\Users\Public\Documents\Autodesk\Inventor 2018\Design Data\DWG-DXF\exportdxf.ini
