Error iLogic Rule by Open Drawing from Vault
petr_suchomel
petr_suchomel
Hello, I created iLogic Rule for update style. The rule I run after open drawing. When I open drawing by command "Open" or from model by "Open drawing" rule run right. When open drawing from model by "Open drawing from Vault" rule crashed.
bradeneuropeArthur
Could you upload the code as text file?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
petr_suchomel
OK, here it is.
bradeneuropeArthur
Try this way:
Dim oDoc = ThisDoc.Document
If oDoc.DocumentType <>  DocumentTypeEnum.kDrawingDocumentObject Then
   Exit Sub
else
Dim oDrawDoc As Inventor.DrawingDocument
oDrawDoc = ThisDoc.Document
Dim i As Integer
For i = 1 To oDrawDoc.StylesManager.Styles.Count
    If oDrawDoc.StylesManager.Styles.Item(i).UpToDate  = False Then
		If oDrawDoc.StylesManager.Styles.Item(i).Name = "Výchozí norma (DIN)" Then
			oDrawDoc.StylesManager.Styles.Item(i).UpdateFromGlobal
				MsgBox("Macro OK",,"IdwStylesUpdate")
Next i
 or better:
If oDoc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then Dim oDrawDoc As Inventor.DrawingDocument oDrawDoc = ThisDoc.Document else exit sub End If Dim i As Integer For i = 1 To oDrawDoc.StylesManager.Styles.Count If oDrawDoc.StylesManager.Styles.Item(i).UpToDate = False Then If oDrawDoc.StylesManager.Styles.Item(i).Name = "Výchozí norma (DIN)" Then oDrawDoc.StylesManager.Styles.Item(i).UpdateFromGlobal MsgBox("Macro OK",,"IdwStylesUpdate") End If End If Next i
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
petr_suchomel
Your rules generate the same error which I sended.
jaco011
Did you find an solution? I am searching too
