iLogic to determine if Files have more than One Model State
arkelec
arkelec
Is this possible?
I've had a look at a few articles, but can't see anything that suits.
What I ultimately want to do, is to establish whether a file has more than one Model State & if it does, return a boolean value of 1 to a custom parameter.
Thanks in advance.
bradeneuropeArthur
This will do:
It will create a PMst parameter with a value of 1 if there are more than one Modelstate in the Assembly.
Dim a As AssemblyDocument = ThisAssembly.Document
Dim c As AssemblyComponentDefinition = a.ComponentDefinition
Dim UPs As UserParameters = c.Parameters.UserParameters
Dim Up As UserParameter
If c.ModelStates.Count>1 Then
Try
	Up = UPs.Item("PMst")
	Catch
	UPs.AddByValue("PMst",1,"ul")
	End Try
End If
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
arkelec
Cheers @bradeneuropeArthur.
I modified your code to work with both Part & Assembly files & also configured it to create an enabling parameter for another parameter (via a form).
Here's the code, in case it helps anyone else:
Sub Main()
' Notes:
' Vars:
' Get the active document:
Dim oDocType = ThisDoc.Document.DocumentType
' Code for PART:
If oDocType = DocumentTypeEnum.kPartDocumentObject Then
	Dim oPartDoc As PartDocument = ThisDoc.Document
	Dim oPartDef As PartComponentDefinition = oPartDoc.ComponentDefinition
	Try
		Parameter("MSQ") = Parameter("MSQ")
	Catch
		oPartDoc.ComponentDefinition.Parameters.UserParameters.AddByValue("MSQ", False, "BOOLEAN")
	End Try
	If oPartDef.ModelStates.Count>1 Then
		Parameter("MSQ") = True
	End If
' Code for ASSEMBLY:
ElseIf oDocType = DocumentTypeEnum.kAssemblyDocumentObject Then
	Dim oAssemblyDoc As AssemblyDocument = ThisDoc.Document
	Dim oAssemblyDef As AssemblyComponentDefinition = oAssemblyDoc.ComponentDefinition
	Try
	Catch
		oAssemblyDoc.ComponentDefinition.Parameters.UserParameters.AddByValue("MSQ", False, "BOOLEAN")
	End Try
	If oAssemblyDef.ModelStates.Count>1 Then
	End If
End If
End Sub
