06:41 AM
I found and modify slightly a code below which is working very good for me but i would like to add Yes/No message box.
Can anyone have a look and help me with this??
Imports SysIO = System.IO Sub Main() 'See if there are any open views If (ThisApplication.Views.Count > 0) Then 'Setup Translator to dwg Dim DWGAddIn As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC2-122E-11D5-8E91-0010B541CD80}") Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = kFileBrowseIOMechanism ' Create a NameValueMap object Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium 'Go through each view and save if it's a drawing document For Each view As View In ThisApplication.Views If view.Document.DocumentType = kDrawingDocumentObject Then 'Get the directory file is saved in. Can replace this with specific directory Workspacepath = ThisDoc.WorkspacePath () WorkspacePathLength = Len (Workspacepath) Pathonly = ThisDoc.Path Directorypath = strings.right(pathonly, pathonly.length-WorkspacePathLength) DWGPath = "\\VPE-SERVER\Drawings\" & Directorypath If(Not System.IO.Directory.Exists(DWGPath))Then System.IO.Directory.CreateDirectory(DWGPath) End If Dim dwgDir = DWGPath 'Get name of file without the extension and add _acad2k to it. oDataMedium.MediumType = kFileNameMedium oDataMedium.FileName = dwgDir & "\\" & _ SysIO.Path.GetFileNameWithoutExtension(view.Document.FullFileName) & _ "_acad2k.dwg" ' Check whether the translator has 'SaveCopyAs' options If DWGAddIn.HasSaveCopyAsOptions(view.Document, oContext, oOptions) Then 'Use Export To DWG to save drawing configuration and set here Dim strIniFile As String = "\\VPE-SERVER\Drawings\Template\Inventor\Templates\DWGOut.ini" ' Create the name-value that specifies the ini file to use. oOptions.Value("Export_Acad_IniFile") = strIniFile 'Save File DWGAddIn.SaveCopyAs(view.Document, oContext, oOptions, oDataMedium) End If End If Next End If End Sub
