I found a somewhat similar post about adding a custom iProperty value to a selection set and I would like to try to modify it to author the iProperty description field with the sub-assembly's occurrence name. I have tried to adapt the attached code but can't seem to make anything happen.
For instance, I want the 52101-037-2 1/2"-PP14-S53-H2 (which is a user modified occurrence name) to be copied to the description for that sub-assembly.
Here is the code I found:
Sub Main() Dim oDoc As Document oDoc = ThisApplication.ActiveDocument Dim comps As SelectSet Dim comp As ComponentOccurrence comps = oDoc.SelectSet 'If there are selected components we can do something, otherwise we're done If comps.count = 0 Then Exit Sub Dim aDoc As DocumentsEnumerator aDoc = oDoc.AllReferencedDocuments Dim iDoc As Document Dim cName As String Dim cTS As String Dim sTS As String Dim FNP As Long Dim cFNP As Long Dim docFN As String For Each iDoc In aDoc sTS = iDoc.FullFileName FNP = InStrRev(sTS, "\", - 1) docFN = Mid(sTS, FNP + 1, Len(sTS) - FNP) For Each comp In comps cTS = comp.Name cFNP = InStrRev(cTS, ":", - 1) cName = Left(cTS, cFNP - 1) If cName = Left(docFN, Len(docFN)-4) Then 'Set iProperty in each of the selected parts in assembly iProperties.Value(docFN, "Custom", "Mark") = "this part is now marked" End If Next Next End Sub
