Change parameter depending of view
atomic.lex
atomic.lex
Hello there and happy new year !
I've tryied to change a parameter depending of view, unfortunately unsuccessful. Any ideas?
Dim oAsmCompDef As AssemblyComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
Dim oCompOcc As Inventor.ComponentOccurrence
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item("min").activate
	Distance_A = 10
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item("max").activate
	Distance_A = 15
All the best for you
Alex
dgreatice
I'm try you code and work.
Can you provide screenshot?
and better all of you code insert to here.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
