iLogic to add iAsssembly table column
Is this possible to do via iLogic without going through the ExcelWorksheet object?
MechMachineMan
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
I looked at the relevant help files before posting here. The iAssemblyTableColumns object (at least according to the 2015 API help) has the following methods Properties: Application, Count, Type, and Item. The iAssemblyTableColumn object has the following method: Delete.
My post here was to possibly get feedback on what can/can't be done with iLogic so I don't waste any more time.
Best Regards
MechMachineMan
It's definitely looking like you're SOL, IMO. Inventor does heavily rely on Excel, so it does make sense that regardless of what your are doing, if it involves Excel, it's going to be going through excel whether you intend it to or not.
Justin K
