iLogic - Sum of a Custom iProperty Without Adding the Suppressed Components
Message 1 of 14
Please see the code that I have been working through below.
The goal is to sum up the total of a custom iProperty called MSRP.
I seem to have everything working well however the moment I suppress something I get an Unspecified Error.
Any help would be greatly appreciated,
Riese
SyntaxEditor Code Snippet
'- - - - - - - - - - - find or create custom iProperty - - - - - - - - - -
'Define the open document & make Library Files Editable (IV 2018)
ThisApplication.[_LibraryDocumentModifiable] = True
Dim openDoc As Document
openDoc = ThisDoc.Document
'Look at all of the files referenced in the open document
Dim docFile As Document
For Each docFile In openDoc.AllReferencedDocuments
Dim propertyName1 As String = "MSRP"
'define custom property collection
oCustomPropertySet = docFile.PropertySets.Item("Inventor User Defined Properties")
Try
'look for property
oProp = oCustomPropertySet.Item(propertyName1)
Catch
' Assume error means not found so create it
oCustomPropertySet.Add(0, propertyName1)
End Try
Next
'- - - - - - - - - - - sum the custom iProperty - - - - - - - - - -
'clear the custom property in the assembly
iProperties.Value("Custom", "MSRP") = 0
'set a reference to the assembly component definintion.
'This assumes an assembly document is open.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
'check for and skip virtual components
'(in case a virtual component trips things up)
If Not TypeOf oOccurrence.Definition Is VirtualComponentDefinition Then
'Property In the Assembly
xNumber = iProperties.Value("Custom", "MSRP")
'property in the parts
yNumber = iProperties.Value(oOccurrence.Name, "Custom", "MSRP")
sumNumber = xNumber + yNumber
'set property values
iProperties.Value("Custom", "MSRP") = Round (sumNumber,2)
MSRP = sumNumber
Else
Next
Replies (13)
Message 2 of 14
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @Anonymous,
iLogic code looks fine for me. Can you please specify "what are you trying to suppress to get unspecified error"?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 14
MechMachineMan
The issue is because a suppressed file has reduced load in memory, so I think not all API of it is accessible.
You should be able to add in a test and either unsuppress/measure/resuppress, or skip the file according.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-75CCD20D-728B-4B77-B950-263E297A68EC
Also helps for readability/reusability/general programming to properly encapsulate the code (splitting it into logical sub-routines) instead of leaving it as a procedural code.
Sub Main()
ThisApplication
.[_LibraryDocumentModifiable] = True Dim openDoc As Document openDoc = ThisDoc.Document
Call SetInitialMSRPValues(openDoc)
Call SumMSRP(openDoc as Document)
End Sub
Sub SetInitialMSRPValues(openDoc As Document)
Try
oProp
Catch
End Try
Next
End Sub
Sub SumMSRP(openDoc as Document)
oAsmCompDef = openDoc.ComponentDefinition
If oOccurrence.Suppressed = True
MsgBox(oOccurrence.Name & " is suppressed. Excluding from MRSP!")
Else
MSRP = sumNumber
End if 'Suppressed
End If 'Virtual Component
Next
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 4 of 14
Hi Justin,
Thanks for your reply and the suggested solution, I found it very helpful how you had organized the the code into logical sub routines.
I have a number of years experience with Inventor and the Vault Pro environments , but have only now just begun taking courses in VBA and iLogic.
So for the moment my scripting knowledge is still quite limited but anything that I can pick up or learn is greatly appreciated.
I tested what you had provided as a solution but ran into a small error that I am not able to fix myself.
In the statement
the As calls up  the following error " ' ) ' expected"
Please see the attached screenshot.
I have also included a small zipped up version of the assembly that I am working with if that helps.
If we can get this working properly it should be of benefit to many others.
Riese
Message 5 of 14
Hi Chandra,
I appreciate you looking at the iLogic code this morning.
I created a little video and placed it on A360 at http://a360.co/2mepX0F as an illustration to help demonstrate the error on a small sample project.
(The files are all zipped up and included in my reply to Kevin BTW)
I appreciate the solution offered by Kevin, but could this code be made to work with iLogic, all by it self?
Of course  iLogic has its limitations, compared to VBA, but it would be too bad if using a full blown VBscript is the only solution for this.
Thanks for any help,
Riese
Message 6 of 14
The 'as' statement shouldn't have been in the functino call.
Sub Main()
ThisApplication
Call SumMSRP(openDoc)
End Sub
Try
oProp
Catch
End Try
Next
End Sub
Else
MSRP = sumNumber
End if 'Suppressed
Next
End Sub
Message 7 of 14
Thanks Justin,
I appreciate your help your script works perfectly now except if I suppress a component then I get the following error.
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.ComponentOccurrence.get_Definition()
at LmiRuleScript.SumMSRP(Document openDoc)
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Any ideas?
Best Regards,
Riese
Message 8 of 14
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @Anonymous,
Try the following iLogic code to calculate MSRP for assembly.
Sub Main()
End Sub
        Try
        Catch
        End Try
    Next
End Sub
Sub SumMSRP(openDoc As Document)
        Else
                	MSRP = sumNumber
	End If 'Suppressed
    Next
End Sub
Actually, failed to retrieve definition of occurrence if it is suppressed. Before checking virtual component definition, check whether occurrence is suppressed or not.
Please feel free to contact if there is any queries.
If problem is solved, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 9 of 14
Hi Chandra,
What I have noticed now is that if I run the updated rule, I successfully get the notices regarding each suppressed component, the MSRP calculation does not change  and then the error message again pops up again.
However if I run the rule a second time it then works perfectly, without any error and the MSRP calculations are correctly updated.
We must be close to a solution.
Best Regards,
Riese
Message 10 of 14
MechMachineMan
So you are saying you want it to calculate the MSRP for the suppressed components too?
Justin K
Message 11 of 14
No, sorry for not being clear.
Whatever is 'active' in the custom level of detail,( in my case it is called "MyLOD"), needs to have all of it's custom numeric iProperties "MSRP" summed up as a total.
Whatever is suppressed in that custom LOD should just be ignored and not included..
Riese
Message 12 of 14
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @Anonymous,
For me, its working fine. Please refer the following screencast for more details.
Sub Main()
    ThisApplication.[_LibraryDocumentModifiable] = False
End Sub
        Try
        Catch
        End Try
    Next
End Sub
    Else
        	MSRP = sumNumber
	End If 'Suppressed
    Next
End Sub
The only change I made is "ThisApplication.[_LibraryDocumentModifiable] = False".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 13 of 14
Hi Chandra & Justin,
Thanks very much for your help, patience and extra effort.
In my case I do need the statement "ThisApplication.[_LibraryDocumentModifiable] = False", set to "True" since in the production model there are a number of library parts and a release IV 2018.2 "fix" necessitates its inclusion.
Having said that, I spent a good part of the day poking around and learning some more.
It seemed that I needed to save the assembly before the MSRP calculator would work properly, since it would fail the first time I ran it, but then work perfectly when I ran it the second time.
But then I tried a completely different approach on my current project leaving your code exactly as is.
I used
ThisApplication.ActiveDocument.ComponentDefinition.RepresentationsManager.LevelofDetailRepresentations("iLogic").Activate
 to set the various LoD's that I require.
Then I used a multi-value User Defined Property to activate each of the LoD's, each with its own iteration of the assembly that I am working on.
The MSRP calculator now works immediately and perfectly.
I have it updating instantly as any additional modifications are made to each unique LoD.
Again I really appreciate the help you have provided and hope it will help some others as well.
Appreciatively Yours,
Riese
Message 14 of 14
Hi Chandra,
This code is very useful. Is there a way to make it ignore parts that don't have the value we are looking for?
Rather than making it add to the parts.
Also, if I wanted to nock off a value {200mm for example}
Would that be possible?
When I add to the end of the code it doesn't subtract, and when I add to the middle it multiples the number by the number of parts I think.
Thank you!
