05:31 PM
I find this code. It's good work.
but Do not check Parts List exists.
I want to add a check function.
Public Sub CreatePartsList() 'On Error Resume Next ' Set a reference to the drawing document. ' This assumes a drawing document is active. Dim oDrawDoc As DrawingDocument Set oDrawDoc = ThisApplication.ActiveDocument 'Set a reference to the active sheet. Dim oSheet As Sheet Set oSheet = oDrawDoc.ActiveSheet ' Set a reference to the first drawing view on ' the sheet. This assumes the first drawing ' view on the sheet is not a draft view. Dim oDrawingView As DrawingView Set oDrawingView = oSheet.DrawingViews(1) ' Set a reference to th sheet's border Dim oBorder As Border Set oBorder = oSheet.Border Dim oPlacementPoint As Point2d If Not oBorder Is Nothing Then ' A border exists. The placement point ' is the top-right corner of the border. Set oPlacementPoint = oBorder.RangeBox.MaxPoint Else ' There is no border. The placement point ' is the top-right corner of the sheet. Set oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width, oSheet.Height) End If ' Create the parts list. Dim oPartsList As PartsList Set oPartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint) End Sub
Thank you.
