How do I check Parts List exists vba?
I find this code. It's good work.
https://forums.autodesk.com/t5/inventor-customization/place-parts-list/m-p/5841794/highlight/true#M5...
but Do not check  Parts List exists.
I want to add a check function.
Public Sub CreatePartsList()
'On Error Resume Next
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
'Set a reference to the active sheet.
Dim oSheet As Sheet
Set oSheet = oDrawDoc.ActiveSheet
' Set a reference to the first drawing view on
' the sheet. This assumes the first drawing
' view on the sheet is not a draft view.
Dim oDrawingView As DrawingView
Set oDrawingView = oSheet.DrawingViews(1)
' Set a reference to th sheet's border
Dim oBorder As Border
Set oBorder = oSheet.Border
Dim oPlacementPoint As Point2d
If Not oBorder Is Nothing Then
' A border exists. The placement point
' is the top-right corner of the border.
Set oPlacementPoint = oBorder.RangeBox.MaxPoint
Else
' There is no border. The placement point
' is the top-right corner of the sheet.
Set oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width, oSheet.Height)
End If
' Create the parts list.
Dim oPartsList As PartsList
Set oPartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint)
End Sub
 Thank you.
dgreatice
To check if partslist table already exist add more code:
Dim oSheet As Sheet
Else
End If
on error resume next
Set oPartsList = oSheet.PartsLists.item(1)
if err.number <> 0 then
else
'Do Nothing or if you want to edit existing partlist
end if
End Sub
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Thank you~
it's work. Very well.
dgreatice
Accept as solution?
