iLogic setting sheet metal defaults using form drop down
beth.maddux
beth.maddux
Okay so I am trying to link when I make a selection in my form to trigger a change in my sheet metal default material. I just cant figure out how to code this to make that change. Is this something I can do with iLogic?  I made sure the material in the spreadsheet matches the material in the sheet metal defaults. So everything should be the same.
bradeneuropeArthur
Could you please try to explain what you try to do, because I don't understand exactly what you try to acheive.
Regards.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
beth.maddux
So I want to set my material in the sheet metal defaults from my form. So if I make a change from my drop down I want it to change the sheet metal rule as well.
