iLogic send email with selected parts and attach pdf
Neuzzo
Neuzzo
Hi, i've this macro that get the selected file, collect it and open an email with this selected parts name in a body.
I wanna attach a pdf to this email but i don't find a solution.
All pdf is in
\\server-ut01\DISEGNI\PDF\
and it's name is same as part name.
Example:
- Part name "SGE3000001.ipt"
- Pdf name  "SGE3000001..pdf"
in a folder \\server-ut01\DISEGNI\PDF\
Can anyone help me? Thanks
Sub Main()
'Make a ref to active doc
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
'selected components collection
Dim oSelected As ObjectCollection
oSelected = ThisApplication.TransientObjects.CreateObjectCollection
Dim oCount As Integer
oCount = oDoc.SelectSet.Count
'Check that at least 1 is selected
If oCount = 0 Then
	'MessageBox.Show("Please select a component.", "iLogic")
	Exit Sub 'bail out
'add to Object Collection
Dim i As Long
For i = 1 To oCount
	If oDoc.SelectSet.Item(i).Type = _
		ObjectTypeEnum.kComponentOccurrenceObject Then
		oSelected.Add (oDoc.SelectSet.Item(i))
Next
  ' Start Outlook.
 ' If it is already running, you'll use the same instance...
   Dim oOApp
   oOApp = CreateObject("Outlook.Application")
' Log on. Doesn't hurt if you are already running and logged on...
   Dim olNs
   olNs = oOApp.GetNamespace("MAPI")
   olNs.Logon
For Each oItem In oSelected
	oMsg = oMsg & vbLf & Left(oItem.Name, Len(oItem.Name) - 2)
Next
'send email using outlook
Dim oOMail
oOMail = oOApp.CreateItem(olMailItem)
With oOMail
            'replace with your client's email address
            .To = ""
            .Subject = InputBox("Nome del cliente.", "iLogic", "") '"Please Review: "
          .Body = "Particolari da produrre:" & vbLf & oMsg
'            .Body = .Body & "Thanks, " & myName
            .Display
			For Each oMsg
            objOutlookAttach = .Attachments.Add("\\server-ut01\DISEGNI\PDF\" & oMsg 6 ".pdf"(True))
			Next
	End With
End Sub
The code for this operation is
For Each oMsg
			Next
and obviously is incorrect. Can someone have idea to fix it?
Danilo "DannyGi" G.
Mechanical design engineer and product developer
bradeneuropeArthur
objOutlookAttach = .Attachments.Add("\\server-ut01\DISEGNI\PDF\" & oMsg & ".pdf"(True))
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Neuzzo
@bradeneuropeArthursyntax error message in
For Each oMsg
Thisi is error now
Danilo "DannyGi" G.
Neuzzo
I've try with single file but error appear: "index over Matrix limit" in italian "indice oltre i limiti della matrice"
The code is
objOutlookAttach = .Attachments.Add("\\server-ut01\DISEGNI\PDF\" & "SGE30093430" & ".pdf"(True))
Danilo "DannyGi" G.
Neuzzo
Now it work! 🙂
Sub Main()
If oCount = 0 Then
	Exit Sub 'bail out
Dim i As Long
For i = 1 To oCount
Next
  ' Start Outlook.
   Dim oOApp
   Dim olNs
   olNs.Logon
Dim oOMail
With oOMail
            .To = ""
            .Display
				oMsg = oMsg & vbLf & Left(oItem.Name, Len(oItem.Name) -2)
				oMsg1 = Left(oItem.Name, Len(oItem.Name) -2) 'Left(oItem.Name, Len(oItem.Name) -2)
				objOutlookAttach = .Attachments.Add("\\server-ut01\DISEGNI\PDF\" & oMsg1 & ".pdf")
			Next
	End With
End Sub
If someone need it, just select some parts in an assembly and run rule.
Obvs change folder in rule to your pdf folder (or what you want)
Danilo "DannyGi" G.
