Hi @bruce.blundell,
Ask and ye shall receive:
Option Explicit On
Imports Inventor.SelectionFilterEnum
''' <summary>
''' This rule asks the user to select a workplane and a point to decide on the number of slices.
''' The program then works out the spacing between the two selections.
''' It does require the workplane normal to be facing into the part as there is no intelligence to determine if that is the case after selection.
''' </summary>
Sub Main
Dim trans As Transaction = ThisApplication.TransactionManager.StartTransaction(ThisApplication.ActiveDocument, "Slice and export tool")
transGeom = ThisApplication.TransientGeometry
Try
Dim Cont As Boolean = True
Dim Counter As Integer = 1
Dim oDoc As Document = ThisDoc.Document
If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject OrElse oDoc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
MessageBox.Show("This tool can only be used in a part file!", "No slicing for you!", _
MessageBoxButtons.OK,MessageBoxIcon.Exclamation, _
MessageBoxDefaultButton.Button1)
Return
Dim oPartCompDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim oWorkPlanes As WorkPlanes = oPartCompDef.WorkPlanes
Dim oFilter As SelectionFilterEnum = SelectionFilterEnum.kWorkPlaneFilter
' Turn origin planes on
For a = 1 To 3
oWorkPlanes.Item(a).Visible = True
Next
' Get start plane from user
Dim oStartPlane As WorkPlane = ThisApplication.CommandManager.Pick(oFilter, "Select Start Plane")
Dim slicingEndPoint As Object = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPointEntities,"Select a point to slice between")
Dim GridlineName As String = InputBox("Enter Name of Grid Planes", "Say my name!", "GL")
If GridlineName = "" Then
Cleanup(oWorkPlanes)
Return
Dim StartNo As Double = 10
' Dim Offset As String = InputBox("Enter Plane Offset in mm (From Previous)" & vbLf & vbLf & "Hit cancel to finish", Title, StartNo)
Dim totaloffset As Double = ThisApplication.MeasureTools.GetMinimumDistance(oStartPlane, slicingEndPoint)
Dim numPlanes As Double = CDbl(InputBox("Enter Number of planes" & vbLf & vbLf & "Hit cancel to finish", "Planes, Planes, Planes", StartNo))
Dim offset As Double = totaloffset / numPlanes
Dim oNewWorkPlane As WorkPlane
'1 less than total slices because otherwise there's nothing to slice.
For i As Integer = 0 To numPlanes -1
Dim CountString As String = i.ToString("D4")
If i = 0 Then
oNewWorkPlane = oStartPlane
Else If i = 1 Then
oNewWorkPlane = oWorkPlanes.AddByPlaneAndOffset(oStartPlane, offset)
Else
oNewWorkPlane = oWorkPlanes.AddByPlaneAndOffset(oNewWorkPlane, offset)
Try
oNewWorkPlane.Name = "Work Plane" & GridlineName & CountString
Catch
End Try
Dim newSketch As PlanarSketch = CreateSketch(oPartCompDef, oNewWorkPlane)
oNewWorkPlane.Visible = False
newSketch.ProjectedCuts.Add()
newSketch.Edit()
newSketch.ExitEdit()
newSketch.Name = GridlineName & CountString
ExportSketch(newSketch)
newSketch.Visible = False
If newSketch.SketchLines.Count > 0 Then
' newSketch.exp
' offset += offset
Next i
trans.End()
Catch
trans.Abort()
End Try
End Sub
Sub ExportSketch(ByVal thisSketch As PlanarSketch)
'Export face to pre-defined folder
Dim selSet As SelectSet = ThisApplication.ActiveDocument.SelectSet
If selSet.Count = 0 Then
selSet.Select(thisSketch)
Dim oFolder As String = ThisDoc.Path & "\" & ThisDoc.FileName & "DXF\"
If Not System.IO.File.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder)
Dim oFileName As String = oFolder & thisSketch.name & ".dxf"
Dim oCmdMgr As CommandManager
oCmdMgr = ThisApplication.CommandManager
Call oCmdMgr.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, oFileName)
Call oCmdMgr.ControlDefinitions.Item("GeomToDXFCommand").Execute
End Sub
Public OriginSketchPoint As SketchPoint = Nothing
Public transGeom As TransientGeometry = Nothing
Sub Cleanup(ByVal oWorkPlanes As WorkPlanes)
' Turn origin planes off
For a = 1 To 3
oWorkPlanes.Item(a).Visible = False
Next
End Sub
''' <summary>
''' Creates a sketch based on a workplane
''' </summary>
''' <param name="compDef"></param>
''' <param name="plane"></param>
''' <returns></returns>
Public Function CreateSketch(ByVal compDef As ComponentDefinition, ByVal plane As WorkPlane) As PlanarSketch
Dim newSketch As PlanarSketch = compDef.Sketches.Add(plane)
Call CorrectForMissingOriginPoint(compDef, newSketch)
If Not newSketch Is Nothing Then
Return newSketch
Else
Return Nothing
End Function
''' <summary>
''' Checks if the supplied planarsketch has the part originpoint projected into it (if created by the API it won't!) and if not adds it.
''' </summary>
''' <param name="thisSketch"></param>
Public Sub CorrectForMissingOriginPoint(ByVal compDef As ComponentDefinition, ByRef thisSketch As PlanarSketch)
Dim oOriginWP As WorkPoint = compDef.WorkPoints.Item(1)
'set as global above
' Dim oOriginSketchPoint As SketchPoint
For Each oSketchPoint As SketchPoint In thisSketch.SketchPoints
If oSketchPoint.ReferencedEntity Is oOriginWP Then
OriginSketchPoint = oSketchPoint
Exit For
Next
' Create the sketch point for the origin, if it doesn't already exist.
If OriginSketchPoint Is Nothing Then
' Project the origin point onto the sketch.
OriginSketchPoint = thisSketch.AddByProjectingEntity(compDef.WorkPoints.Item(1))
End Sub
Here is the rule in action:
And attached is the sample part I built in Inventor 2019 along with the .dxf sample files created above.
Cheers,
Alex.
PS. This rule doesn't "split" the solid body as per your original request, but it could I believe be modified to do so fairly easily.
