export building components using api
can someone please share me the code that i can write in vba(inside inventor) for creating a button that will export my file to adsk format?
HermJan.Otterman
it is already in Inventor,
Environment, Bim Content
export building components...
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
sir i know about that but i want to do it with the help of inventor api and thats why i am asking about the code  that can be written in vba which is provided inside inventor?
Private Sub CommandButton1_Click()
    Dim strFullFileName As String
    strFullFileName = "C:\Users\Yogesh\Desktop\model1.ipt"
Dim o2 As BIMComponent
Set o2 = BIMComponent.ExportBuildingComponent(strFullFileName)
End sub
but this didnt work!
HermJan.Otterman
look at:
https://forums.autodesk.com/t5/inventor-ideas/export-ifc-and-rfa-files-with-inventor-api/idi-p/67209...
BIMComponent.ExportBuildingComponent Method BIMComponent.ExportBuildingComponent( FullFileName As String )
Input String that defines the full filename to write the building component to. The filename should have an adsk extension.
Herm Jan
