iLogic: Save As
iLogic: Save As
Message 1 of 30
iLogic: Save As
Does anyone know how to make a rule that automatically performs a "Save As" to a specific directory AND a specific name?
Ideally, the rule is run from the part document. The rule then opens up a specific drawing document, performs a "Save As" function to the same directory as the file part, and names the drawing file the same as the part file.
I already figured out how to get drawing file name to be the same as the part file name, but I cant get it to save to a specific directory. It always pops up a file dialog box.
Replies (29)
Message 2 of 30
mwighton
I found this code online, which displays a window to allow the user to choose the save location.
SyntaxEditor Code Snippet
'define the active document
    oDoc = ThisDoc.Document
    'create a file dialog box
    Dim oFileDlg As inventor.FileDialog = Nothing
    InventorVb.Application.CreateFileDialog(oFileDlg)
    'check file type and set dialog filter
    If oDoc.DocumentType = kPartDocumentObject Then
    oFileDlg.Filter = "Autodesk Inventor Part Files (*.ipt)|*.ipt"
    Else If oDoc.DocumentType = kAssemblyDocumentObject Then
    oFileDlg.Filter = "Autodesk Inventor Assembly Files (*.iam)|*.iam"
    Else If oDoc.DocumentType = kDrawingDocumentObject Then
    oFileDlg.Filter = "Autodesk Inventor Drawing Files (*.idw)|*.idw"
    End If
    'set the directory to open the dialog at
    oFileDlg.InitialDirectory = ThisDoc.WorkspacePath()
    'set the file name string to use in the input box
    oFileDlg.FileName = iProperties.Value("Project", "Part Number")
    'work with an error created by the user backing out of the save
    oFileDlg.CancelError = True
    On Error Resume Next
    'specify the file dialog as a save dialog (rather than a open dialog)
    oFileDlg.ShowSave()
    'catch an empty string in the imput
    If Err.Number <> 0 Then
    MessageBox.Show("No File Saved.", "iLogic: Dialog Canceled")
    ElseIf oFileDlg.FileName <> "" Then
    MyFile = oFileDlg.FileName
    'save the file
    oDoc.SaveAs(MyFile, False) 'True = Save As Copy & False = Save As
    End If
 You can change the line which states:
so a specific path(if you know the extension)
You can also remove the lines that display the window.
Hope this helps.
Did this post help out? Hope it did.
If so please use the 'Accept as Solution' or 'Kudos' Button below.
God Bless
Mwighton
Message 3 of 30
Hmm, but the issue is i DONT want a window to display asking the user where he wants to save the drawing file. The reason is a little complicated, but it boils down to the fact that the user would be specifying where he wants to save the drawing file beforehand (specifically when he is prompted to save his part file). The drawing file is only allowed to open AFTER the user saves his part file. Upon the drawing file opening, I need it to automatically do a "Save As" into the same directory where the user just saved his part file.
It is funny, because the code you posted is the exact same one I use for the saving of the users part file.
Message 4 of 30
mwighton
So after the first save add a line that will save the workspace path as a variable and use that as the save location in the code I provided. Once that is completed add the open document line.
God Bless
Mwighton
Message 5 of 30
Yes but how do I specify the parameter for the save location without having a save file dialog box open up?
Here is my relevant section of code.
    'save the file
    MessageBox.Show("Loaded")
    ThisDoc.Launch(oDrawingFileTemplate)
    Dim oDrawingDoc as DrawingDocument = ThisApplication.Documents.Item(oDrawingFileTemplate)
    oDrawingDoc.DisplayName = ThisDoc.Document.DisplayName
    oDrawingDoc.SaveAs(MyFile & ".idw", False)
Message 6 of 30
BrandonBG
Are you trying to get to the path of the part file? Or is the drawing being save elsewhere?
With the part file open, try oPath = ThisDoc.Path
Then load the drawing, and save with
oDrawingDoc.SaveAs(oPath & MyFile & ".idw", False)
Brandon
Message 7 of 30
I am trying to save in the same directory as the part file. Ah, silly me, I didnt realize that the first parameter in the SaveAs function can be extended to also include the desired path, and is not just for the file name.
However, I tried this and it still opens up a Save filedialog box. I am not sure how to get to save without opening a dialog box.
Message 8 of 30
BrandonBG
I think the dialog pops up because MyFile is declared as oFileDlg.FileName.
Does it work to insert this before the SaveAs?
Dim oDrawingFile As String
oDrawingFile = MyFile
oDrawingDoc.SaveAs(oPath & oDrawingFile & ".idw", False)
Brandon
Message 9 of 30
I dont think thats the issue.
I enetered:
MessageBox.Show(ThisDoc.Path & "\" & MyFile & ".idw")
to see what it said. It said:
So Im pretty sure it was right before.
Message 10 of 30
BrandonBG
I was using the string manipulation to get past the File Dialog prompt. Did it do that?
I forgot that you'll need to extract the path/filename and strip off the file extension.
Brandon
Message 11 of 30
Ok, using messagebox, I got the correct file name and path finally to:
oDrawingDoc.SaveAs(ThisDoc.PathAndFileName(False) & ".idw", False)
However, it is still popping up a SaveAs dialog box, with the initial directory not changing to the same one as the part file. Its almost as if the SaveAs function for the drawing is completely ignoring the parameters I've set for it, and is using the parameters set for the SaveAs dialog for the part file.
Message 12 of 30
Using the following I get the correct path and everything. It still pulls up the file dialog box.
MessageBox.Show(ThisDoc.PathAndFileName(False) & ".idw")
Message 13 of 30
MechMachineMan
    'save the file
The oFileDialog is telling it to open up the large dialog window.
I don't know what other window you would be talking about...
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 14 of 30
Sorry, I way I copied it might have been a bit miseading, but the oFileDialog is actually for saving the part file, not the drawing file. From the code, you can see my Drawing document (dimensioned as oDrawingDoc) is only launched after the part file is succesfully saved. The problems I am running into involve the saving of the drawing document (oDrawingDoc) in the same directory and with the same file name as my part file.
Here is a larger section of the relevant code. Its the same base code that you posted in your first reply, except with additional items in the "ElseIf" section where the file actually gets saved.
(Edit: Sorry MechMachineMan, not the same base code that you posted, I meant the base code that BrandonBG posted in his first reply)
        oShowSave = False
        'save the file
        oPath = ThisDoc.PathAndFileName(False)
        'Launch the Drawing Document
        MessageBox.Show(oDrawingDoc.FullFileName) 'for troubleshooting purposes
        oDrawingDoc.SaveAs(oPath & ".idw", False)
        Update_Drawing = True
    End If
Message 15 of 30
MechMachineMan
So what part are you having issues with/ what's happening?
Justin K
Message 16 of 30
The issue is the File dialog box showing twice. I need it to only show once, when I am getting the user to save his/her part file. It should not be showing again when saving the drawing file. It should be automatically saving (specifically "Saving As") the drawing file with the same file name and to the same directory as the part file.
Example of my code running ideally:
  • I open my part file, titled "GENERIC-RING.ipt"
  • My rule is run
  • It prompts the user to Save As to a directory (eg. Save As "C:\Users\thukon\My Documents\12345.ipt")
  • The Drawing document, GENERIC-RING.idw, is launched
  • The Drawing document is then, also saved as "C:\Users\thukon\My Documents\12345.idw"
And this needs to all be done all in one swoop, with the only user intervention being the user choosing where he wants to save the part file.
Message 17 of 30
MechMachineMan
K. I think you are calling the function twice then. Whatever the name of your function is, should only appear once, and immediately assigned to a variable. then manipulated from there.
Justin K
Message 18 of 30
The only thing being called twice is the SaveAs function. From what I gathered on other posts, the SaveAs function itself should not trigger a file dialog.
Thats what the Inventor.FileDialog.ShowSave is for, right? At least FileDialog.ShowSave is what my code uses to prompt the user to save the part file. Hoping someone can correct me here.
Message 19 of 30
mwighton
if you are using the same code that i posted it will prompt a window.
God Bless
Mwighton
Message 20 of 30
BrandonBG
I stripped this down to the essential SaveAs function.
Dim oDrawing as DrawingDocument
oDrawing = ThisDrawing.Document
MessageBox.Show(ThisDoc.Path)
oDrawing.SaveAs(ThisDoc.Path & "\1234.idw", True)
I did not get a file dialog window. However, when I swith the boolean to False, I crash out of the rule.
Brandon
