iLogic Rules
iLogic Rules
Jose_Merino
iLogic Rules
Jose_Merino
I have an assembly, This assembly have the chance to have an inlet right or left, I made a rule to change that in the body, that is OK, because of the inlet, this bracing of this assembly change, because also this inlet can be in different angles, so I made an assembly with all my bracing, and add some rules in here, every single rule works, except for one, I don't know what is wrong in my rule, because If i choose in my Parameters the option CW (Clockwise) or CCW (Counter Clockwise) I want to turn off the one that i don't choose, but it doesn't do that, and I try other options but I can reach a solution, I add some pictures to yo to see my Parameters, my Assembly tree, and my rule if any body could help me with one solution
Thank You.
MechMachineMan
Use productivity tools to rename browser nodes then try again?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
