Ilogic rules, creating triggers
Thetigerpirro
Message 1 of 52
Thetigerpirro
Hi, I have a external rule that I would like to add a trigger to itself (or interna rule) once triggered. I can't seem to find a good way to do this, so suggenstions are appreciated.
Have a nice day.
Replies (51)
Message 2 of 52
asiteur
It is not very clear what you are asking because a rule that triggers itself would cause an endless loop.
If you want to make sure that another rule is triggered after the first, you could add a user defined parameter at the end of the first rule:
trigger_01=trigger_01+1
and at the beginning of the last.
dim trigger As trigger_01
Because the rule updates the parameter, all rules that contain this parameter will be excecuted.
Hope this helps!
Alexander Siteur
Project Engineer at MARIN | NL
LinkedIn
Message 3 of 52
Tigerpirro
I think i might have explained poorly.  What I want is for the rule to set a trigger for itself or other rules in the prat/assembly, for example, "run before save".
Message 4 of 52
Curtis_Waguespack
Hi Tigerpirro
It looks like asked about this a few months ago, did that suggestion not work?
https://forums.autodesk.com/t5/inventor-customization/ilogic-set-event-triggers-from-rule/td-p/66075...
I hope this helps.
Curtis
Message 5 of 52
Tigerpirro
Yes that works but it is to roundabout a way of doing it in this application. I am trying to minimise the code to one external and one internal rule without the need for third files, templates, paths, programs and so on.
I have been trying for a while and it has turned out to be a much bigger challenge that I initially thought.
Have a nice day.
Message 6 of 52
Curtis_Waguespack
Hi Tigerpirro,
Here's something I have on hand, that I've tried in the past but can not get to work. Maybe @MjDeck could help us with this?
I hope this helps.
Curtis
'On Error Resume Next
Auto = iLogicVb.Automation
Dim iLogicAuto As Object
iLogicAuto = Auto
Dim oiLogicDoc As Document
'capture current document
oiLogicDoc = ThisApplication.ActiveDocument
'load up ilogic automation
Dim oiLogicAuto As Object = iLogicVb.Automation
'Get container For all Of the ilogic rules
Dim oRules As Object = oiLogicAuto.rules(oiLogicDoc)
'variable For the events rules
Dim oiLogicPropSet As PropertySet
'Set our Property Set since we know it exists Now
oiLogicPropSet = oiLogicDoc.PropertySets.Item("iLogicEventsRules")
oiLogicPropSet.Add("Rule2", "BeforeDocSave0", 700)
'oiLogicPropSet.Add("N:\CAD\Inventor\iLogic\myExternalRule.iLogicVb", "BeforeDocSave0", 700)
'Event Trigger Name:                    : Property Name 	 				: Property ID
'After Open Document					: AfterDocOpen                 		: 400
'Close(Document)						: DocClose                     		: 500
'Before Save Document                   : BeforeDocSave           			: 700
'After Save Document               		: AfterDocSave               		: 800
'Any Model Parameter Change        		: AfterAnyParamChange   			: 1000
'Part Geometry Change**            		: PartBodyChanged         			: 1200
'Material Change**                  	: AfterMaterialChange     			: 1400
'Drawing View Change***               	: AfterDrawingViewsUpdate  			: 1500
'iProperty(Change)                  	: AfterAnyiPropertyChange           : 1600
'Feature Suppression Change**          	: AfterFeatureSuppressionChange   	: 2000
'Component Suppression Change*   		: AfterComponentSuppressionChange 	: 2200
'iPart / iAssembly Change Component* 	: AfterComponentReplace   			: 2400
'New Document                         	: AfterDocNew                  		: 2600
Message 7 of 52
Thetigerpirro
I can't get it to run. Everything seems to be working smothly up to the last two codes.
SyntaxEditor Code Snippet
'oiLogicPropSet.Add("A", "BeforeDocSave0", 700)
'oiLogicPropSet.Add("C:\_Wahlter\Anpassningar_Library\iLogic\U.txt", "BeforeDocSave0", 700)
Message 8 of 52
MechMachineMan
Hopefully this works a little better. It's using code I've gathered from the multiple threads about the issue. Largely MegaJerk's contributions.
Sub Main()
    oiLogicPropSet = GetiLogicEventPropSet(oiLogicDoc)
'If adding more than 1 trigger of the same type, you need to increment the values;
oiLogicPropSet.Add("Rule2", "BeforeDocSave0", 700) 'oiLogicPropSet.Add("Rule3", "BeforeDocSave1", 701)
End Sub
Function GetiLogicEventPropSet(cDocument As Document) As Inventor.PropertySet
iLogicEventPropSet = cDocument.PropertySets.Item("iLogicEventsRules")
If iLogicEventPropSet Is Nothing Then
iLogicEventPropSet = cDocument.PropertySets.Item("_iLogicEventsRules")
If iLogicEventPropSet.InternalName <> "{2C540830-0723-455E-A8E2-891722EB4C3E}" Then
Call iLogicEventPropSet.Delete
iLogicEventPropSet = cDocument.PropertySets.Add("iLogicEventsRules", "{2C540830-0723-455E-A8E2-891722EB4C3E}")
MsgBox ("Unable to create the Event Triggers property for this file!", , "Event Triggers Not Set")
Err.Raise(1)
Exit Function
On Error Goto 0
Return iLogicEventPropSet
End Function
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 9 of 52
DRoam
@MechMachineMan, the above code only seems to work if there are no existing rules under the desired trigger. Is this true? Can this be fixed?
Also, it throws an error if the desired rule is already under the desired trigger. Can this be fixed as well?
Also, do you have any code for deleting a rule of a specific name under a specific trigger if it's already there?
Message 10 of 52
MechMachineMan
As I have commented in the code, if you want to use the same trigger for
various rules, you have to increment the values in the line.
Yes, just delete the iProperty that has the corresponding information.
Probably best done as a function that loops through the propertyset;
I.e.;
Sub DeleteTrigger(oEventPropset As PropertySet, oRuleName as String,
oTriggerType As String)
.. code
End Sub
Justin K
Message 11 of 52
DRoam
I realized what I was doing wrong. I had 3 existing rules under my trigger, so I had to change the third argument number to 704 (which I did), but I also had to increment the second argument (the name) to "BeforeDocSave4".
I guess, as a precaution in case there are already several existing triggers, I should assign it a large number like "750" and "BeforeDocSave50"? Is that reasonable?
I.e.;
.. code
End Sub
Hm ok, I'll see if I can come up with the code to loop through the correct trigger and delete the correct rule.
Thanks.
Message 12 of 52
MechMachineMan
I have no clue of the intricacies of the incrementing. You might have to
just test it out by trial and error.
Justin K
Message 13 of 52
MechMachineMan
Here is a sample of a sub to delete a specific trigger for a specific rule.
'PropValue is Rule Name
'PropName is the TriggerName
'PropID is the Trigger #
Sub DeleteTrigger(oEventPropset As PropertySet, oPropValue As String, oPropName As String)
	Dim oProp As Inventor.Property
	For j = oEventPropSet.Count To 1 Step-1
		oProp = oEventPropSet.Item(j)
		If oProp.Value = oPropValue And oProp.Name Like oPropName & "*"
			oProp.Delete
			Exit Sub
	Next
End Sub
to implement it, remove the # at the end of the Trigger name as shown in the example below and it will delete it regardless of the increment.
Sub Main()
    Dim EventPropSet As Inventor.PropertySet
    EventPropSet = GetiLogicEventPropSet(ThisApplication.ActiveDocument)
    'Call ListiProps(EventPropSet)
    Call DeleteTrigger(EventPropset, "Rule0", "BeforeDocSave")
End Sub
Justin K
Message 14 of 52
DRoam
Thanks for that, @MechMachineMan. I utilized that to make the rules below.
@Thetigerpirro / @Tigerpirro, this is the only code that you need to put in the rule that you want to check for the Event Trigger in:
'This code will fire an external iLogic rule which will add or remove a rule to/from the specified trigger.
SharedVariable("myRuleName") = "Rule0"                  'This is the name of your rule. Include the full path for an external rule.
SharedVariable("myTrigger") = "Before Save Document"    'This is the trigger name exactly as it appears in the Event Triggers dialog box
SharedVariable("myAction") = "Add"                      'Type "Add" to add the rule to the specified trigger or "Remove" to remove it
iLogicVb.RunExternalRule("EventTriggerSet")
SharedVariable.RemoveAll()
Then, you need to create an External Rule called "EventTriggerSet" which contains the following code:
Sub Main()
	'This code will add or remove a rule to/from the specified trigger.
	'It gets its instructions from shared variables created by another  rule.
	'It relies on the sub "SetRuleTrigger" and the function "GetEventTriggersSet".
	Try
		myRuleName = SharedVariable("myRuleName")    'This is the name of your rule. Include the full path for an external rule.
		myTrigger = SharedVariable("myTrigger")      'This is the trigger name exactly as it appears in the Event Triggers dialog box
		myAction = SharedVariable("myAction")        'Type "Add" or "Remove"
	Catch
		MessageBox.Show("The required inputs were not sent properly to the EventTriggerSet External Rule." & vbNewLine & vbNewLine & "Exiting rule", "EventTriggerSet Error",MessageBoxButtons.OK,MessageBoxIcon.Error)
		Exit Sub
	End Try
	Call SetRuleTrigger(myRuleName, myTrigger, myAction)
End Sub
Sub SetRuleTrigger(oRuleName As String, myTrigger As String, oAction As String)
	'MessageBox.Show("Attempting to access Event Triggers set.") '***DEBUGGING***
	'Get access to the set of Event Triggers
	Dim oEventTriggersSet As PropertySet
    oEventTriggersSet = GetEventTriggersSet(ThisApplication.ActiveDocument)
	'MessageBox.Show("Event Triggers set accessed successfully!") '***DEBUGGING***
	'Get the proper Trigger name and ID
	Select Case myTrigger
		Case "After Open Document"
			oTriggerName = "AfterDocOpen"
			oTriggerID = 400
		Case "Close Document"
			oTriggerName = "DocClose"
			oTriggerID = 500
		Case "Before Save Document"
			oTriggerName = "BeforeDocSave"
			oTriggerID = 700
		Case "After Save Document"
			oTriggerName = "AfterDocSave"
			oTriggerID = 800
		Case "Any Model Parameter Change"
			oTriggerName = "AfterAnyParamChange"
			oTriggerID = 1000
		Case "Part Geometry Change"
			oTriggerName = "PartBodyChanged"
			oTriggerID = 1200
		Case "Material Change"
			oTriggerName = "AfterMaterialChange"
			oTriggerID = 1400
		Case "Drawing View Change"
			oTriggerName = "AfterDrawingViewsUpdate"
			oTriggerID = 1500
		Case "iProperty Change"
			oTriggerName = "AfterAnyiPropertyChange"
			oTriggerID = 1600
		Case "Feature Suppression Change"
			oTriggerName = "AfterFeatureSuppressionChange"
			oTriggerID = 2000
		Case "Component Suppression Change"
			oTriggerName = "AfterComponentSuppressionChange"
			oTriggerID = 2200
		Case "iPart / iAssembly Change Component"
			oTriggerName = "AfterComponentReplace"
			oTriggerID = 2400
		Case "New Document"
			oTriggerName = "AfterDocNew"
			oTriggerID = 2600
	End Select
	'First check if the rule trigger already exists.
	'While we're at it, count the rules already in the Trigger of interest. If we need to add our rule trigger, we'll use this later on.
	'MessageBox.Show("Attempting to check if rule trigger already exists.") '***DEBUGGING***
	oRuleCount = 0
	Dim oRuleTrigger As Inventor.Property
	For Each oRuleTrigger In oEventTriggersSet
		If oRuleTrigger.Name Like oTriggerName & "*" Then
			oRuleCount = oRuleCount + 1
			If oRuleTrigger.Value = oRuleName Then
				'Our trigger does exist.
				If oAction = "Add" Then
					'The rule trigger already exists, so we don't need to add it. Exit the sub.
					'MessageBox.Show("Trigger found! Exiting rule.") '***DEBUGGING***
					Exit Sub
				Else If oAction = "Remove" Then
					'MessageBox.Show("Trigger found! Attempting to remove.") '***DEBUGGING***
					oRuleTrigger.Delete
					'We did what we came to do. Exit the sub.
					'MessageBox.Show("Trigger removed! Exiting rule.") '***DEBUGGING***
					Exit Sub
	Next
	'If we got to here, the rule trigger wasn't found.
		'If we came to delete the rule trigger, it didn't exist anyway, so exit the sub.
		'MessageBox.Show("Trigger not found! Exiting rule.") '***DEBUGGING***
		Exit Sub
	Else
		'If we came to add the rule trigger, add it.
		'MessageBox.Show("Trigger not found! Attempting to add.") '***DEBUGGING***
		'We already counted how many rules are already in our trigger.
		'We can use this to determine what ID name and number to assign to our new rule trigger.
		'Since the ID counts start at 0, we don't have to add 1 to our count.
		Dim oIDName As String = oTriggerName & oRuleCount
		Dim oIDNumber As Integer = oTriggerID + oRuleCount
		'MessageBox.Show("ID name = " & oIDName & vbNewLine & vbNewLine & "ID Number = " & oIDNumber) '***DEBUGGING***
		'Add our rule trigger
		oEventTriggersSet.Add(oRuleName, oIDName, oIDNumber)
		'MessageBox.Show("Trigger added! Exiting rule.") '***DEBUGGING***
		'Exit the rule.
		Exit Sub
End Sub
Function GetEventTriggersSet(oDoc As Document) As Inventor.PropertySet
    oEventTriggersSet = oDoc.PropertySets.Item("iLogicEventsRules")
    If oEventTriggersSet Is Nothing Then
        oEventTriggersSet = oDoc.PropertySets.Item("_iLogicEventsRules")
    If oEventTriggersSet.InternalName <> "{2C540830-0723-455E-A8E2-891722EB4C3E}" Then
        Call oEventTriggersSet.Delete
        oEventTriggersSet = oDoc.PropertySets.Add("iLogicEventsRules", "{2C540830-0723-455E-A8E2-891722EB4C3E}")
        Err.Raise(1)
        Exit Function
    On Error Goto 0
    Return oEventTriggersSet
End Function
Yes, the External rule is very long. And maybe @MechMachineMan or @Curtis_Waguespack or someone else could make it be much more compact and efficient that I could. But the good news is you don't need to put this code in any of your rules. You just create that External rule once and then use the code in the first box to fire it whenever you want to add/remove a rule to an Event Trigger.
I tested it as best I could and it seems to work well, but it's probably not perfect. Please post here if you find any issues.
Hope this works for you.
Message 15 of 52
Thetigerpirro
Thanks, I will check this out as soon as I have the time.
Message 16 of 52
Dean.kichenbrand
Good day DRoam I have used the rule and it works great but I need help with adding external rules, when I add an external rule it adds it to event trigger but it doesn't trigger how do I add the file path of the external rules to your rule please help.
thanks Dean
Message 17 of 52
DRoam
@Dean.kichenbrand, sure, I think I know what you need to do. Just go to the Tools tab, click the bottom "Options" button with the down arrow (the title of the panel), and click "iLogic Configuration".
There you can add the path of your external iLogic rules. Keep in mind that Inventor does NOT automatically include sub-folders of the directories you add. So you'll need to add each folder that actually contains your rules, you can't just add a top-level folder that contains folders with rules.
I've been using the rules above in my workflow for some time now and they've been working great, glad they're working for you, too!
Message 18 of 52
Dean.kichenbrand
Thanks for the reply the problem is that after I run the rule to add the external rules to the event trigger the triggers doesn't work but the external rules name is there but its almost like they're not linked or the rule can't be found as shown on the picture so what I'm asking can I add a path to the rule in the rule.
example:
SharedVariable("myRuleName") = "C:\ILOGIC RULES\AREA"                  'This is the name of your rule. Include the full path for an external rule.
or is there something I did wrong
thanks a lot
Dean Kichenbrand
Message 19 of 52
DRoam
Ah you know what, I completely forgot that I couldn't get the code to work right with adding External rules. What I ended up doing was adding some lines to the beginning of the first code snippet (the shorter one, that you have to add to your "source rule") to first create a LOCAL iLogic rule which contains a single line commanding Inventor to fire the desired External rule. And then you use the remaining lines to fire the supplementary External Rule (the long one) which adds the newly-created local rule to the Event Trigger of choice. It ended up looking like this:
Sub Main
Dim RuleName As String = "Before Save Document"   ' This is the name of your local rule that will fire the desired External rule
Dim RuleText As String = "iLogicVb.RunExternalRule(""SmartPart Before Save Document"")"    'Leave all quotation marks and change the text inside the quotation marks to the name of the External Rule you wish to trigger (do not include the Path)
Dim oDoc As Document = ThisDoc.Document
Dim iLogicAddIn As ApplicationAddIn = ThisApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}")
' Get the iLogic automation object
Dim iLogic As Object = iLogicAddIn.Automation
' Get the list of iLogic rules in the current Inventor document
Dim oRuleList As Object = iLogic.Rules(oDoc)
If oRuleList Is Nothing Then Goto AddRuleStart
Dim oRule As Object
For Each oRule In oRuleList
    If oRule.Name = RuleName Then
        ' A rule with the same name already exists...
        Exit Sub
Next
AddRuleStart:
iLogic.AddRule(oDoc, RuleName, RuleText)
SharedVariable("myRuleName") = "Before Save Document"   'This is the name of your rule. Include the full path for an external rule.
SharedVariable.Remove("myRuleName")
SharedVariable.Remove("myTrigger")
SharedVariable.Remove("myAction")
End Sub
So not as nice and compact as originally. I think I could change things around a bit to make the code you have to put in your "source rule" more compact. If I get the chance I'll do that.
But unfortunately this is the best solution for now. I don't think there's a reliable way to add external rule triggers using iLogic. Our best hope is for this idea to be implemented: Add iLogic functions for handling Event Triggers. Please give it a vote if you haven't already. Thanks!
Message 20 of 52
Dean.kichenbrand
AWESOME !! THANKS ITS WORKING NOW
