iLogic, set Event triggers from rule
Tigerpirro
Tigerpirro
I want my rule to set up Event triggers for itself from inside the rule. Is there a good way to do this?
Curtis_Waguespack
Hi Tigerpirro,
You can copy the event triggers that are set in another file (a template for instance).
http://adndevblog.typepad.com/manufacturing/2015/01/add-external-ilogic-rule-to-event-trigger.html
my modified version of  the example at that link is below. I set up external rules with event triggers in the templates, and then I have this "Copy Event Triggers rule" called from various other external rules as needed. Keep in mind, I repurposed the rule I found at the adndevblog, so there is likely some extra stuff in there that is not needed, etc. I never did go back through it and clean it up.
I hope this helps.
Curtis
Imports System.Collections.Generic
'code taken and modified from:
'http://adndevblog.typepad.com/manufacturing/2015/01/add-external-ilogic-rule-to-event-trigger.html
Sub Main
Trace.WriteLine("Event Driven Rules Copy", "iLogic") 'debug
	Dim oTemplateDoc As Document
	Dim oTemplate As String
	'check file type
	If ThisApplication.ActiveEditDocument.DocumentType = kDrawingDocumentObject Then
	'If ThisDoc.Document.DocumentType = kDrawingDocumentObject Then
		oTemplate = "\\server\departments\CAD\Inventor\Templates\Standard.idw"   'file to copy events from
	ElseIf ThisApplication.ActiveEditDocument.DocumentType = kPartDocumentObject Then
	'ElseIf ThisDoc.Document.DocumentType = kPartDocumentObject Then
		oTemplate = "\\server\departments\CAD\Inventor\Templates\Standard.ipt"   'file to copy events from
	Else
		oTemplate = "\\server\departments\CAD\Inventor\Templates\Standard.iam"   'file to copy events from
	'file to copy events to
	oInput =  ThisApplication.ActiveEditDocument.FullFileName
	If oInput = "" Then 'catch a new file with no path
		Return
	'open the template
	oTemplateDoc = ThisApplication.Documents.Open(oTemplate, False)
	CopyEventsToDocuments(oTemplateDoc)
	oTemplateDoc.Close
End Sub
Private Const m_ourGuid As String = "{2C540830-0723-455E-A8E2-891722EB4C3E}"
Private savedEnabled As Boolean
Dim oInput As String
Public Sub CopyEventsToDocuments(ByVal sourceDoc As Document)
	Dim sourcePropSet As PropertySet = GetEventRulesPropertySet(sourceDoc)
	Dim inputs() As String = { oInput}
	Dim destinationFileNames As List(Of String) = New List(Of String)(inputs)
	If (destinationFileNames Is Nothing) Then Return
	savedEnabled = iLogicVb.Automation.RulesOnEventsEnabled
	iLogicVb.Automation.RulesOnEventsEnabled = False
	Try
		CopyEventsToAllDocuments(sourcePropSet, sourceDoc, destinationFileNames)
	Finally
		iLogicVb.Automation.RulesOnEventsEnabled = savedEnabled
	End Try
End Sub
Function GetEventRulesPropertySet(ByVal sourceDoc As Document) As PropertySet
	Try
		Return sourceDoc.PropertySets(m_ourGuid)
	Catch ex As Exception
		Return Nothing
	End Try
End Function
Function VerifyRulesPropertySet(ByVal propSet As PropertySet) As Boolean
	If (propSet Is Nothing) Then Return True
	' See if any rules are internal instead of external.  We can't copy those.
	For Each prop As Inventor.Property In propSet
		Dim strValue As String = prop.Value.ToString
		If (Not strValue.StartsWith("file://")) Then Return False
	Next
	Return True
End Function
Sub CopyEventsToAllDocuments(ByVal sourcePropSet As PropertySet, ByVal sourceDoc As Document, ByVal destinationFileNames As List(Of String))
	For Each fileName As String In destinationFileNames
		If (String.Equals(sourceDoc.FullFileName, fileName)) Then Continue For
		CopyEventsToDocument(sourcePropSet, fileName)
	Next
End Sub
Sub CopyEventsToDocument(ByVal sourcePropSet As PropertySet, ByVal fileName As String)
	'Dim doc As Document = FindOpenDocument(fileName)
	Dim openedHere As Boolean = False
	If (doc Is Nothing) Then
		doc = ThisApplication.Documents.Open(fileName, True)
		openedHere = True
	CopyEventsPropertySetToDocument(sourcePropSet, doc)
End Sub
Sub CopyEventsPropertySetToDocument(ByVal sourcePropSet As PropertySet, ByVal doc As Document)
	' If an event-driven rules property set already exists, delete it.
	Dim oldPropSet As PropertySet = GetEventRulesPropertySet(doc)
	If (oldPropSet IsNot Nothing) Then
		oldPropSet.Delete()
	If (sourcePropSet Is Nothing OrElse sourcePropSet.Count = 0) Then Return
	Dim destPropSet As PropertySet = doc.PropertySets.Add("_iLogicEventsRules", m_ourGuid)
	For Each prop As Inventor.Property In sourcePropSet
		destPropSet.Add(prop.Value, prop.Name, prop.PropId)
	Next
	EnsureDocumentInterest(doc)
End Sub
Const iLogicId As String = "{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}"
Sub EnsureDocumentInterest(ByVal doc As Document)
	If (ThisApplication.SoftwareVersion.Major < 15) Then Return ' Inventor 2010 or before
	If (DocumentHasiLogicInterest(doc)) Then Return
	Dim dataVersion As Integer = 20090512
	Dim newInterest As DocumentInterest = doc.DocumentInterests.Add(iLogicId, "iLogic", DocumentInterestTypeEnum.kInterested, dataVersion, Nothing)
End Sub
Function DocumentHasiLogicInterest(ByVal doc As Document) As Boolean
	Dim interest As DocumentInterest = FindDocumentInterest(doc, iLogicId)
	If (interest IsNot Nothing) Then
		If (interest.InterestType = DocumentInterestTypeEnum.kInterested) Then
			Return True
		interest.Delete()
	Return False
End Function
Function FindDocumentInterest(ByVal doc As Document, ByVal clientId As String) As DocumentInterest
	For Each interest As DocumentInterest In doc.DocumentInterests
		If (String.Equals(interest.ClientId, clientId, StringComparison.OrdinalIgnoreCase)) Then
			Return interest
	Next
	Return Nothing
End Function
@Curtis_Waguespack wrote:
Hi Tigerpirro,
You can copy the event triggers that are set in another file (a templa...
Sorry to reply to an old post, but I can't get this to work properly. I get it to copy my 2 event triggers to the new file, but only one of them runs initially when it should. The other doesn't run. When I open the event triggers window, both rules are there. First (which runs as it should) runs on before save, and creates a flat pattern if it doesn't exist. The second runs (or should run) on iproperty change, and updates the material and thickness of the sheet metal part according to two custom iproperties.
BUT, if I open the event triggers window, and then press OK (without changing anything), then it works perfectly. If I just press cancel, it still doesn't run.
Any ideas what might cause this?
MechMachineMan
I didnt look at the code very carefully, but i would guess that it may not be increment the same type of triggers.
ie; if you have two triggers for before save, one needs to be 200 and the next needs to be 201. any additional ones would have to be 202, 203, 204, and so on.
Good luck.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Where do I see the increment of the trigger? And change them?
I do only have one trigger for each of the two events.
When I place this rule in an event it doesn't work. I doesn't set the events properly, they are not named (the attached images shows it). When the event occurs I get the error message:
Event driven iLogic rule
RunRule: Found no rule with name ""
(it only translated from the german warning so it might be different in detail)
Why does it not set the new events properly when this rule is event driven? It works if I fire it manually...
I have to add: I added this rule in an event in my template, so when I run it once manually, it will be in the current document. There it works once and then the error I descriped occurs...
