iLogic Rule to match the BOM number & description of 2 different parts
I want to create an iLogic rule which allows me to select a part in an iam file and then select multiple parts after this to match the BOM description & number to.
This would be much quicker then opening the BOM & manually updating the part Number & Description to round up similar parts. (I.e mirrored frame generator parts which it does not recognise as the same part)
The prompt would be something like;
-Select base part
-Select parts to match BOM Number & Description to base part values
-Finish
Sandy
MechMachineMan
Without continuously prompting for more selections, InteractionEvents are where you want to start.
If you are fine with a prompt window between each receiving part, or making the program error out, you can use the command manager PICK method.
There will be examples in this file:
"C:\Program Files\Autodesk\Inventor 2016\Local Help\admapi_20_0.chm"
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
